Keep getting flats on stock tires
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoRancher, Jun 20, 2022.
  1. Jun 21, 2022 at 8:38 PM
    #101
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Just a quick question have you thought about trading the truck in for a good horse? I’m sure it would get less flats probably even better gas mileage plus his shifting would be better and his frame probably won’t rust out.:boink:
  2. Jun 22, 2022 at 4:29 AM
    #102
    TacoRancher
    TacoRancher [OP] Well-Known Member
    Houston
    2024 Trail Hunter, 2022 Lime PRO (RIP)
    Have you ever gone 300 miles in a vehicle with 1 horsepower? Also… is rust still an issue!
  3. Jun 22, 2022 at 4:35 AM
    #103
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I know they’re aren’t KO2’s, but with my E load Grabbers I averaged 23-24 MPGs on my last road trip. Just throwin’ it out there for the OP’s consideration.
    Im not saying Grabbers are better, just that you can still get good MPGs with E rated tires.
    TacoRancher[OP] likes this.
  4. Jun 22, 2022 at 4:44 AM
    #104
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I'm not going to read all responses. But I will say that E tires are not a cure all. I recently had a spear shaped rock (1.5" exposed, .5" at the tip, 2" long) imbed itself in the dead center of my E tire and cause it to go flat. Rock was still wedged in when I took it in to get fixed. My driving is on forest service roads.
    A higher range tire will reduce the frequency, but you can still puncture them .
    Your best bet would be to upgrade your tires a bit and build & carry a repair kit with plugs and a compressor. I personally suggest building an on-board air system with a quick connect at the back bumper (can fill tires on truck and trailer). This will allow you to reduce pressure off-road and the refill before you get on the road.
  5. Jun 22, 2022 at 4:44 AM
    #105
    TacoRancher
    Houston
    once I upgrade to C or E load, air down, and also inspect all my trails for sharp ground cover, I’ll be in good shape - super helpful thanks everyone
    Road_Warrior[QUOTED] likes this.
  6. Jun 22, 2022 at 4:45 AM
    #106
    TacoRancher
    Houston
    100% agree with all this.
  7. Jun 22, 2022 at 4:53 AM
    #107
    TacoRancher
    Houston
    I’m thinking to get the ARB compressor that I can bolt down into the engine bay.
