Keep hitting my Fenders
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Codyboi, Nov 30, 2009.
  1. Nov 30, 2009 at 11:04 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    3inch Revtek spacer lift, 33inch Goodyear Duratrac with 17inch Helo rims, K&N CAI
    Well i have a 3 inch spacer lift with add a leaf in the back of my 05 tacoma and i keep hitting my fenders with my 33s. My friend told me to add a 1 inch body lift but i cant find one lower than 3. does anyone know if they even make 1 inch body lifts for 2nd gen tacomas?
  2. Nov 30, 2009 at 11:04 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Did you trim the inner fender? Where are you rubbing specifically?
  3. Nov 30, 2009 at 11:55 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    I generally like avoid body lifts like the plague...but I know you can make them yourself, or take a 3 inch kit and cut them down to size.
    If I were you, I'd save up and upgrade the suspension lift, and not mess around with a crapload of spacers (because that's what a body lift really is).
  4. Dec 1, 2009 at 12:17 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    show pics of where its rubbing. may be able to easily trim it down. for the prerunners u can get the 4" lift spindles for height and even add some CO's to get more
  5. Dec 1, 2009 at 4:10 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    Yeah i trimed the inner fender and even some of the black plastic but it still manages to hit parts of the back...its hard to tell where exactly it hits but i noticed a my tread on the outside had a small piece missing.
  6. Dec 1, 2009 at 4:28 PM
    jhodge83
    SC
    17 XLT Sport
    you may be rubbing on the cab mount. have someone cut the wheel all the way over until the back of the wheel is tucked in and see if they are hitting the cab mount. if so, the way people are fixing that is having it cut and rewelded
  7. Dec 1, 2009 at 4:50 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    well what i feared just happened...i was going about 5 mph and i was turning and i hit about 8 inches up from the bottom so from the bottom of the fender 8 inches up there is a black paint chip mark...the very tip/corner of my tire tred hit.
  8. Dec 1, 2009 at 6:02 PM
    jhodge83
    SC
    17 XLT Sport
    what are the specs on the wheels and tires?
  9. Dec 1, 2009 at 9:26 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    They are goodyear duratrack 285/70 R17
  10. Dec 1, 2009 at 9:28 PM
    jhodge83
    SC
    17 XLT Sport
    are ur wheels 17x9s?
  11. Dec 1, 2009 at 9:33 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    yeah...i am tepted to just cut off all of my fender from the left side and just try and make the the right side as close as possible...cuz now i have chipped paint
  12. Dec 1, 2009 at 9:34 PM
    jhodge83
    SC
    17 XLT Sport
    that sucks man...i havent heard of anyone having this much rubbing...especially athat far out on the flare
  13. Dec 1, 2009 at 9:39 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    yeah this lift has been a bitch...first my order got screwed up and i only got half a lift...then my rims were sold to someone else so i had to choose new ones...then the tire i wanted wasnt in my size...they gave me the wrong shocks which i have on my truck now...and my rims didnt have long enough studs so i had to buy new studs and get them put on for another $200...and now i cant hit a bump hard turning right or my tire will pop...FML!!!!
    thnx for helping btw i appretiate it
  14. Dec 1, 2009 at 9:41 PM
    jhodge83
    SC
    17 XLT Sport
    do u know the backspacing on those wheels?
  15. Dec 1, 2009 at 9:43 PM
    Codyboi
    Codyboi [OP] Member
    Cody
    California
    05 PreRunner
    no...how can i find out?
  16. Dec 1, 2009 at 9:52 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    look at the website you bought them off or the companys and looks a the specs, itlle be either b.s. or backspacing
  17. Dec 1, 2009 at 9:55 PM
    jhodge83
    SC
    17 XLT Sport
    ^^ that or measure from the inside lip of the rim to where the wheels mount on the inside of the rim.
  18. Dec 1, 2009 at 9:58 PM
    08pretaco
    Oliver
    az
    ^ that works also ;)
  19. Dec 1, 2009 at 9:59 PM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    I also have the duratracs in 285/70/17. Are you talking about the very bottom part of the fender flare, closest to the cab? Because I had to trim a piece on both sides to avoid rubbing. Have you had an alignment done yet? When I had mine done, I asked them to move the wheel as far forward as possible, to avoid possible rub on the body mount. I figured its easier to trim the front part of the wheel well.
  20. Dec 1, 2009 at 10:03 PM
    08pretaco
    Oliver
    az
    how do you move a wheel forward???
