Keep it or scrap it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NHtacomaownah, Mar 7, 2018.
  1. Mar 8, 2018 at 9:38 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    woah, if you have a brand new frame and the truck is paid for, keep it!!!!
    Are you mechanically inclined? If yes, you can do the job for much less than what you have been quoted
    If not, well, find another shop because this $6000 quote is bullshit. You can definitely get it for cheaper
    btw, repairing it will end up less expensive than a a new truck (no payments and the cost of repairs are going to be lower than the price for a new truck)
    Running Board Man likes this.
  2. Mar 8, 2018 at 9:40 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Good Point...they might still be good. But, if you're doing lower ball joints etc it's about another 1-2 hours of work to do the bushings. Any poly bushing options are around $30-$40.
    Mine were cooked at 220,000...depends on the truck. In fact mine were so bad the truck would pull to the left when you hit the brakes. I put a camera looking down from above the shock tower and you could see it move when you it the breaks.
    Here's a link to a short video I made of one side. The other side was actually worse.
    https://photos.app.goo.gl/c2D1ucqf4Lz0PXIr1
    Also no squeaking doesn't mean your bushing are still good. Doesn't mean their bad either.
  3. Mar 8, 2018 at 9:45 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Do the work needed and get that 100K. For what this is going to cost you, (not really much) you'll never find another vehicle as dependable for that next bunch of miles. It's stuff you're going to prob. have to do to ANY 2nd hand truck you buy and if you were wanting new, I guess you would have already went and bought.
    You can do eeett! And remember it doesn't have to all be done in 1 jab.
  4. Mar 8, 2018 at 9:49 AM
    otis24
    Mark
    California
    Good for you...that's your truck though. The OP should ivestigate his own truck to determine that.
    Also, there's a lot of information we don't have. If a mechanic reccommends something at the least it should be looked into further.
    Not disregarded because another truck on a forum claims to have no issues with significantly higher miles. Who knows...maybe your truck only sees highway and the OP's has only seen dirt. On the other hand his truck could be fine and the mechanic is full of shit. right?
    OP...Did the mechanic elaborate on why you should replace control arms? Were they upper or lower?
  5. Mar 8, 2018 at 10:08 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's just it, he probably doesn't.
    Mechanics, mostly dealers, will opt to replace the entire control arm because they come with new inner bushings pre-installed. It is a 5 minute job to swap in the new part, as opposed to removing the control arm, pressing out the old bushing, and pressing in new ones.
    And since YOU are paying for the part, it's a win-win for them.
    otis24 likes this.
  6. Mar 8, 2018 at 10:44 AM
    NHtacomaownah
    NHtacomaownah [OP] Member
    KP
    Tahoe, CA
    02 Tacoma TRD
    Stock
    I'll post pics when I can. I'm working all day.
    scocar and otis24 like this.
  7. Mar 8, 2018 at 12:48 PM
    scocar
    scocar hypotenoper
    otis24 likes this.
  8. Mar 8, 2018 at 1:08 PM
    1997tacomav6
    Denver
    Just over 200,000 miles, it's just getting broken in :))) new frame! Paid for! KEEP IT
  9. Mar 8, 2018 at 1:20 PM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2019 Tacoma TDR Sport 4WD DCLB - Cement - Tech and Premium
    4Runner Trail wheels and Toyo Open Country ATII tires 265-70-17. Cosmetic stuff like Pro grille and OffRoad black bumper trim, vinyl delete on side, added hood graphic, OEM tube steps.
    Pay me $6,000 to do that work and I will put you and your wife up at the Ritz Carlton while the work is being done.
    otis24 and w:ll:s like this.
  10. Mar 8, 2018 at 1:26 PM
    otis24
    Mark
    California
    I forgot to mention I work for OTPHJ's.
