Keep messing up my rear drums, please give me some advice.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pwakchop, Sep 10, 2024.
  1. Sep 10, 2024 at 1:23 PM
    Pwakchop
    Pwakchop [OP] Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    I love this truck, but it has so many little quirks and hiccups (not that it's a bad thing). I have only 17k miles on my 2021 Tacoma TRD Sport and I have had the rear drums warp, be inspected, get resurfaced/replaced, and then warp again 3 times now. I took it to the dealership for one, a highly reviewed brake shop the second time, and did it myself the 3rd time. I'm tired of spending $500+ every year on brake maintenance and am legitimately considering trading the truck in because of this one issue. I am super easy on the brakes, break them in, and avoid coming to complete stops while they are hot. I've tried everything, including having the dealership replacing the axle as when it bends it can warp your rotors. I am out of time, ideas, and patience. Please help. I could get if it happened once, but average time between needing brake components is 5k miles. I really hope that my case is a fluke and none of y'all are experiencing the same pain.
  2. Sep 10, 2024 at 1:33 PM
    84-4runner
    84-4runner Well-Known Member
    frank
    Northern Arizona
    2019 tacoma offroad
    intake mods, firestone airbags, campershell, backup lights,
    do you get them wet when hot?. If you are using them and them get lots of water on/in them they can warp.
    Has happened to me once. At least that is what is sounds like to me.
    Pwakchop[OP] likes this.
  3. Sep 10, 2024 at 1:37 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Are they dragging? Maybe the shoes are adjusted too tight
  4. Sep 10, 2024 at 1:38 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  5. Sep 10, 2024 at 1:38 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I haven't had to replace any brake component yet, aside from two preemptive fluid changes.
    :anonymous:
    MOC221_ and Pwakchop[OP] like this.
  6. Sep 10, 2024 at 1:41 PM
    Pwakchop
    Nate
    Georgia
    First time, I did get them wet but it was about 2 weeks before the first warping (technically not true, someone else said pad deposits). Haven't been off road since. I have an appointment with the dealership Friday, I'm just going to push to have every component replaced. My warranty ends tomorrow but two weekends ago I let the tech drive it and make a note so I'm not SOL. I would assume they're not dragging as I've put it up on jacks to test for it, but then again I am not knowledgable when it comes to brakes. If it was dragging I'd hope one of the two other places would have noticed.
  7. Sep 10, 2024 at 1:42 PM
    Pwakchop
    Nate
    Georgia
    Lucky duck :pout:
  8. Sep 10, 2024 at 1:44 PM
    Pwakchop
    Nate
    Georgia
    It may be helpful if I add that I feel the vibration throughout the truck but not the steering wheel. It's bad enough that I feel like I'm running over a rumble strip and I can't have passengers anymore because it makes them carsick. Slightly embarrassing :rofl:
    robbyk and wilcam47 like this.
  9. Sep 10, 2024 at 1:44 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I hope it gets figured out soon. I have no idea why it would be that persistent.
  10. Sep 10, 2024 at 1:45 PM
    Pwakchop
    Nate
    Georgia
    I appreciate it. My vacuum pump knocks pretty bad (have to get that replaced too) but I doubt that could be causing it.
  11. Sep 10, 2024 at 3:03 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Are the lug nuts too tight?
  12. Sep 10, 2024 at 3:23 PM
    Pwakchop
    Nate
    Georgia
    I torqued them to spec during my last tire rotation, so unfortunately no. Can’t figure it out for the life of me. Thank you for the help
  13. Sep 10, 2024 at 3:59 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Check out this video from the Maintenance Map and make you are not missing something.
    https://youtu.be/-dmUF5hbQEQ?si=M0VfoV5BW73Nk-Q7
  14. Sep 10, 2024 at 4:05 PM
    BillF1564
    BillF1564 Well-Known Member
    2021 Tacoma SR
  15. Sep 10, 2024 at 4:22 PM
    Pwakchop
    Nate
    Georgia
    Just watched, I did everything except the anti-seize. Is that required? I did it via a different write up and they never mentioned it. :eek:
  16. Sep 11, 2024 at 10:14 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    All the linkages and adjusters are dry? :facepalm: Any metal-on-metal interface need grease or anti-seize.
    Taqyto likes this.
  17. Sep 11, 2024 at 11:04 AM
    JohnDeere630
    JohnDeere630 Well-Known Member
    Gary
    Gray 2023 Tacoma SR5
    The elephant in the room here is the constant severe vibration. That ain't normal. I've had 3 Tacomas and never had to mess with the rear brakes until well over 100K miles, and Mine are work trucks & don't get babied. None have ever vibrated either. Figure that vibration out & I'll wager the other problems are related. Possible suggestions: bent or badly out of balance driveshaft, bad rear axle bearings, bent or badly out of balance rims/tires....
    AusBerg, oconnor, AZ Pete and 3 others like this.
  18. Sep 11, 2024 at 11:25 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
  19. Sep 11, 2024 at 11:25 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yes, exactly what I was thinking as I read through.
    Most of the time Tacoma drum brakes are under adjusted and dont do a whole lot. I highly doubt drums are the source of your issue. Also, if they were getting that crazy hot you would smell them
    Carrier bearing? Bad tire balance? Bad tire (not round)? Unbalanced driveshaft (maybe lost a weight)? Many sources of vibrations, but I kinda doubt its the drums
  20. Sep 11, 2024 at 11:32 AM
    SR-71A
    Zack
    Southern Maine
    @Pwakchop what if any mods have you done to the truck?
