Keep messing up my rear drums, please give me some advice.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Pwakchop, Sep 10, 2024.
  1. Sep 11, 2024 at 1:32 PM
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    Driving the taco like its a sports car perhaps?
    Never had drums on my coupe but a heavy foot cost me quite a bit in resurfacing and replacing rotors
  2. Sep 12, 2024 at 10:35 AM
    Pwakchop
    Pwakchop [OP] Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    I put grease instead of anti seize.
    3JOH22A[QUOTED] likes this.
  3. Sep 12, 2024 at 10:37 AM
    Pwakchop
    Nate
    Georgia
    Sorry, been extremely busy with classes. Only mods are OTT, sound system, and bed rack/mounts for my bikes. Even the tires are still stock! Can’t figure out what’s going on!
    SR-71A[QUOTED] likes this.
  4. Sep 12, 2024 at 10:38 AM
    Pwakchop
    Nate
    Georgia
    I consider myself a relatively gentle driver, only sees over 3k RPM maybe twice a week, if that.
  5. Sep 12, 2024 at 10:43 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    List of things that can cause vibrations is extensive. I doubt its the drums. Just some ideas in my other post above
  6. Sep 12, 2024 at 10:47 AM
    Pwakchop
    Nate
    Georgia
    I’ll go through the list this weekend when I can get the wheels off and look at it better! I have an appt at the dealership tomorrow to see if they find anything. I’ll ask them to check the tires balance and I’ll look at the carrier bearing tonight! I’ll see if they would be open to checking for a bent axle, I don’t have much motivation to dig that deep, haha! Thank you again for all of the help!
  7. Sep 12, 2024 at 11:03 AM
    SR-71A
    Zack
    Southern Maine
    :thumbsup:
    Low hanging fruit first aka check/re-balancing tires
    Mater96 and Pwakchop[QUOTED][OP] like this.
  8. Sep 12, 2024 at 1:11 PM
    Pwakchop
    Nate
    Georgia
    I’d do it at home if I had the equipment and know-how! Unfortunately I possess neither :rofl:
  9. Sep 12, 2024 at 8:24 PM
    girMobi
    2020 TRD OFF
    FYI when you pull the drums there is a layer of paper and double sided tape between it and the axle. Its supposed to cut down on brake chatter but makes it harder to remove. i didn't replace it when i put them back and things are still fine.
    just odd seeing paper on things that can get to 400F
    Pwakchop[OP] likes this.
  10. Sep 13, 2024 at 5:34 PM
    Pwakchop
    Nate
    Georgia
    So, as I was driving to the dealership, the vibration completely disappeared. I stopped setting my parking brake this week thinking that maybe it was depositing material/burning in marks when I pulled it after driving. Could that have been what was causing it? Of course it stopped right while I was headed there as they now say it's operating as usual and no vibration is noted. :annoyed:
    wilcam47 likes this.
  11. Sep 13, 2024 at 5:53 PM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    It’s going to be something that was overlooked . Drum brakes although old tech are pretty reliable and decent on the rear of a truck. They get a bad rap for no reason. Just because they are an old design . For heavier vehicles they work totally fine .
    SR-71A, petethemeat and AZ Pete like this.
  12. Sep 13, 2024 at 6:20 PM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    @3JOH22A might have a better idea on this but I know my parking break has caused super funky shit to occur with my truck.
    Pwakchop[QUOTED][OP] likes this.
  13. Sep 13, 2024 at 6:24 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    OP, back off your shoes all the way using the star adjuster. Immediately drive the vehicle without backing up or using the emer brake. If it still vibrates, it's probably not the rear drums.
  14. Sep 13, 2024 at 6:39 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    Drum brakes are usually very reliable and don't cause much issue. It may have been mentions already but I would suspect either the emergency brake adjusted too tight or the automatic adjusters not working correctly.
    atc250r, AZ Pete and Pwakchop[OP] like this.
  15. Sep 14, 2024 at 6:34 AM
    #35
    Pwakchop
    Nate
    Georgia
    So, just got a call back from the dealership and they said that my best bet is to knock out the cheap stuff first. Going to try a $100 four tire balance and see where to go from there.
    Tatts521 likes this.
  16. Sep 14, 2024 at 7:18 AM
    #36
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Do you have aftermarket wheels?
  17. Sep 14, 2024 at 9:36 AM
    #37
    Pwakchop
    Nate
    Georgia
    Unfortunately, no. Stock sport wheels.
    wrightme43[QUOTED] likes this.
  18. Sep 14, 2024 at 2:50 PM
    #38
    wrightme43
    Well, I hope thier plan fixes it.
  19. Oct 14, 2024 at 9:23 AM
    #39
    robbyk
    robbyk Active Member
    Robby
    2024 Tacoma DBCab TRD Off Road 4x4
    OP - I have the same issue, 2015 Tacoma. In my case after replacing the drums, shoes, and new springs the vibration goes away but eventually comes back. The vibration is the same as you described, throughout the truck but not the steering wheel. Please share what the dealership finds out.
  20. Oct 14, 2024 at 11:45 AM
    #40
    tagoo
    tagoo New Member
    2023 TRD Pro Solar Octane MT
    I've seen people constantly set and release the parking brake multiple times at a stop light (nervous habit, I think). Doing this actually adjusts the parking brakes tighter and tighter, creating lots of drag and heat in the rear brakes once you start moving. If you are doing this, stop.
    Ngneer likes this.
