Keep my old taco or buy a new one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Calvin9819, Oct 1, 2020.
  1. Oct 1, 2020 at 1:43 PM
    NMroamer
    NMroamer Well-Known Member
    Fred
    Albuquerque
    2015 TRD OR
    Mine had an LSD rear end. In two wheel drive find a dirt road with loose dirt. Stop and take off quickly, LSD will spin both rear tires.
  2. Oct 1, 2020 at 3:05 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    But on a nice flat gravel road with equal traction in a straight line, would an open diff not spin both as well?
    I think LSD can be determined from the axle code. But I want to say it was only available up until like 2008 or 2009. Dont quote me on that.
    Calvin9819[OP] likes this.
  3. Oct 1, 2020 at 3:11 PM
    HONY BADGER
    HONY BADGER Missing my memes
    BADGER
    2010 DBLB Silver Taco
    What RedWing 44 said why make an issue when one is not present!
  4. Oct 1, 2020 at 3:17 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I’d put in an air locker and regear it. There’s nothing special about a new one.
  5. Oct 1, 2020 at 3:28 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Keep it...without hesitation
  6. Oct 1, 2020 at 6:25 PM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I was about to say it didn't have an LSD, but looking at the brochure, it seems all trims came standard with the Auto LSD. Which isn't a mechanical one, but uses your brake lines to brake your wheel individually.
  7. Oct 2, 2020 at 4:30 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    A limited slip or locking rear diff is of limited help in snow. And in many cases is a handicap. Either MIGHT help get you moving from a stop if you have one wheel on ice and the other on clear pavement. But either will also make it more likely for you to end up in a ditch. If only 1 wheel on the rear axle spins while going around a curve you will continue to travel in the direction you are going. If BOTH rear wheels start spinning gravity takes over and the ass end of the truck goes downhill fast. Since most roads have a crown where the center is higher so water will drain toward the ditches the rear of the truck ends up in the ditch.
    This is where traction control works great. Traction control uses computer sensors that applies brake pressure to the spinning wheel which causes the differential to stop sending power to that wheel and redirects it to the other. You can lightly apply the parking brake to manually do the same thing long enough to get moving in a similar situation.
  8. Oct 2, 2020 at 7:33 AM
    Calvin9819
    Calvin9819 [OP] Member
    Gotcha, I’ll double check the info to see if it has an LSD but I think you’re right by saying they come standard using the brakes instead of an actual clutch pack. The general consensus is keep the beast so that’s what I’ll do. Throw some better suspension in there and run her proudly! Thanks everyone for your input, I’m sure I’ll be back with more questions haha
    SR-71A likes this.
  9. Oct 2, 2020 at 8:16 AM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    Keep it, you'll spend a lot more buying a newer model with tax + fees
  10. Oct 3, 2020 at 1:04 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Cheapest Option.
    Grossomotto likes this.
  11. Oct 3, 2020 at 1:15 AM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    I got a 97 reg cab 4x4 auto with a rear air locker WAYYYYY better than these trail limos out here
  12. Oct 3, 2020 at 2:40 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    With the crazy new prices keep your truck. Plus, MT is really hard to find now.
  13. Oct 3, 2020 at 2:52 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    dont U have a limited slip rear end that WILL pull in snow
  14. Oct 3, 2020 at 2:56 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Keep in mind, per Toyota, the locker is for getting you unstuck rather than for normal driving. I believe it automatically shuts off above a certain speed too. It's low, like 15 mph or less (I don't remember the exact limit). So if you're in a ditch from using the locker, you're doing something very wrong.
