Keep PSI at 35 or lower it to 29?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jimbo1970, May 26, 2022.
  1. May 26, 2022 at 6:59 PM
    LS14ME2
    LS14ME2 Kind of a big deal
    In hiding, CA
    2017 SSM Sport DCSB 4x4
    Center console divider thingy, rubber bed mat and side steps for the wife.
    Interesting, I have a 2017 with the same tires and my sticker has 28psi cold. Maybe because yours is a long bed?
  2. May 26, 2022 at 7:02 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    This sounds perfect OP
  3. May 26, 2022 at 9:04 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Do what?
    FredRed315 likes this.
  4. May 26, 2022 at 9:05 PM
    Bishop84
    Bishop84 Well-Known Member
    I set to 35psi on hot days.
    If I set it to 29psi on a hot day, it will 100% drop below threshold and trigger the light.
    Blame techs all you want, but this is standard practice. Toyota even has a chart for us to go by.
    Also the TPMS reads 2psi lower than most expensive gauges. So we set to 35psi for it to show 33psi on the dash.
    TexasTacoLT, avery0829 and Smacky2020 like this.
  5. May 26, 2022 at 9:15 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have 315/75/16s and my cold pressure is 31 to 32 psi. When I was stock long time ago I ran about 30 to 31 psi
  6. May 27, 2022 at 4:20 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Direct Tire set my new 265/70/16 UltraTerrains at 35psi. Feels pretty good. I’ll be offroad in central Baja this afternoon for 8 daze running 20psi.
    CaptainBart45 likes this.
  7. May 27, 2022 at 5:59 AM
    COMMANDO740
    COMMANDO740 Well-Known Member
    Southernahia
    2022 TRD OFFROAD MAGNETIC GRAY
    On hot days your PSI drops?
  8. May 27, 2022 at 6:14 AM
    pmoore4321
    pmoore4321 Well-Known Member
    San Juan, Puerto Rico
    2021 Tacoma OR
    Read what he wrote again.
    TexasTacoLT likes this.
  9. May 27, 2022 at 6:26 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    I think what he's trying to say is on a hot day where a customer drove for a while to get there, tires are hot and setting them at 29 will guarantee a "return customer" complaint when they start it back up next morning and now their tires are at 26 (with tpms light on).
    I always get home from a rotation and recheck torque and pressure the next morning anyway. I don't hold psi being a little off against whomever did the work because of the above. If they set it at 40+ or something stupid or torque was way off, then will leave some areas of improvement comment on the survey.
  10. May 27, 2022 at 6:27 AM
    mrengineerical
    mrengineerical Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    I like keeping my stock sport at 32 psi. Better ride in my opinion.
    zoo truck and CaptainBart45 like this.
  11. May 27, 2022 at 6:38 AM
    Spn004
    Spn004 Well-Known Member
    22 DC TRD OR SB LR
    This is all totally preference... 35psi will not hurt you though, I've always ran a higher pressure like that.
  12. May 27, 2022 at 6:46 AM
    PokerPilot
    PokerPilot Well-Known Member
    If I set it to 29psi on a hot day, it will 100% drop below threshold and trigger the light. Help me understand how tire pressure drops on a hot day? I'm not following. Thank you in advance.
  13. May 27, 2022 at 6:49 AM
    PokerPilot
    I've never noticed my tire psi drops at any time, hot or cold, when i start up the next day. Sure, if my tires after use are "X" they will certainly by "X-Y" after they cool down but they won't be below the cold starting point from the previous day because the days temperature was warmer. I'm still not following. Sometimes I just can't keep up with everyone, oh well.
  14. May 27, 2022 at 6:58 AM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Good example. Here yesterday in Sacramento, it was 99 degrees. Let’s say I drive my taco to the dealer and they inflate my tires to 35psi. So the tires are “hot” from driving to the dealer, plus it is just a hot day.
    I come home, go to sleep. Next day it’s 55 degrees in the morning when I drive to work. Now my psi might be at 30 psi because of the temp drop.
    you know, when it’s hot, everything expands. When it’s cold, things shrink.
    inwood customs and TexasTacoLT like this.
  15. May 27, 2022 at 7:02 AM
    #35
    COMMANDO740
    Southernahia
    :cheers:
    Everyone take a shot. Maybe we can figure this out.
    3dpilot likes this.
  16. May 27, 2022 at 7:08 AM
    #36
    3dpilot
    3dpilot Well-Known Member
    Damn didn’t know tire pressure can get complicated af lol
    PokerPilot and COMMANDO740 like this.
  17. May 27, 2022 at 7:18 AM
    #37
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    I think you need to read into this a little. He's saying if it's a hot day and he sets his pressure to 29psi, once it cools off outside tire pressure is going to drop and activate the TPMS warning light.
    Bottom line: set your tires to manufacturer recommended pressures. If you have "upgraded" tires, start with manufacturer recommendation, chalk test, and adjust as/if necessary.
    I wouldn't trust anybody but myself to properly inflate my own tires. That being said, a few PSI in either direction isn't going to make much difference. As @Smacky2020 said, it's good practice to recheck pressure and torque ASAP after service visits. Unfortunately, most techs I've met couldn't care less if your tires are inflated to the correct pressure and many (maybe most) will use an impact wrench to re-install the lugs.
  18. May 27, 2022 at 7:19 AM
    #38
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Idk, with 35 psi my butt huts more.
  19. May 27, 2022 at 7:34 AM
    #39
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I've heard of TPMS being + - a pound or so, but not a consistent 2PSI under actual. I check my tires often with a pretty good digital gauge and it registers right-on on three tires and sometimes a pound low on the other (sometime right-on so I'm assuming it's off 1/2 pound or so) do have aftermarket sensors which where replaced when I bought new wheels, so maybe that makes a difference.
    FWIW, I run my tires high @35 pounds which of course needs to be adjusted as seasons change. I have them rotated 2x year and tread wear is perfect and ride is to my liking.
  20. May 27, 2022 at 7:37 AM
    #40
    PokerPilot
    Ah yes. Thank you for clarifying. I was looking at the scenario from the opposite side- the tires were 35 cold. Thank you.
