Keep stock tire size if I'm not going to lift?
Discussion in 'Wheels & Tires' started by tacoma700, Nov 19, 2017.
  1. Nov 19, 2017 at 12:58 PM
    tacoma700
    tacoma700 [OP] Member
    2004 burgundy tacoma prerunner 2wd
    i have a stock 2004 tacoma prerunner 2wd with 265/70/16 . i’m going to need new tires soon and was thinking if i should keep the same size or change it to a bigger one maybe 265/75/16 . i don’t want to put a lift . im looking to get sum yoko geo lander at
  2. Nov 19, 2017 at 1:05 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    Keep stock tire size. If you don't plan on lifting, no need to go bigger in size.
    Bagel likes this.
  3. Nov 19, 2017 at 1:06 PM
    tacoma700
    so i shouldn’t get the 265/75 niether ?
  4. Nov 19, 2017 at 1:29 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    I wouldn't. Why put bigger tires and ruin your mileage? It wont make much of a difference but it will be worse
  5. Nov 19, 2017 at 3:34 PM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    Will you be off roading? Do you need a larger tire? If not then I would go back with the same size, why go bigger if you don't need it for practical use?
    AdventureKid and 90yota like this.
  6. Nov 19, 2017 at 3:50 PM
    01GreenTacoma
    Yep just go with a more aggressive tire and save weight.
  7. Nov 19, 2017 at 3:51 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Look at the Falken Wildpeaks
