Keep the Tacoma and buy Civic???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rangejeep, Feb 4, 2013.
  1. Feb 4, 2013 at 12:13 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Havent done the math of your scenario, but my gut tells me it is not worth it when you factor in maintanance and other costs required to keep the car on the road. I personally would not, and yes, I thought about it. Instead, I carpool to work with my coworker. We take turns to drive. I drive one week, he drives the other. Of coruse I realize it may not be an option for you.
    On the contrary here is an example of my dad:
    My dad got an 02 Saturn LS2 with 120k on it before this winter and parked his 02 Sierra 2wd in the garage under parking insurance. (cheap) He will have it out for the summer, going to the lake, mountains etc. He starts it every weekend and moves it around the driveway once a month or so. Got the saturn for $1900 and sold his winter tires and rims from the truck that he does not need anymore for $750, so the car cost him $1150 eventually. He gets more than double mileage and seems ok with the way it worked out for him. Of course this way he gets to drive only one vehicle at a time...His $300+ monthly fuel bill shrunk to maybe $120. So far it was only cost of fuel, insurance and an oil change on the new car for him. Will see how long it will last.
  2. Feb 4, 2013 at 12:16 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    I say supercharge your truck with the money, you know, for the better gas mileage. :D
    But seriously, remove the block of lead from your foot and you will save a fortune. If you accelerate slowly, and run 65-70 on the interstate, you will save more money then buying a commuter car.
  3. Feb 4, 2013 at 12:22 PM
    Sje1124
    Sje1124 Well-Known Member
    Sean
    Louisiana
    2010 DBL Cab TRD OR 4x4
    Just a few
    I am also in the same situation right now. I drive 230 miles to and from work 3 times a week. Should be getting a civic or corolla in the next few months.
  4. Feb 4, 2013 at 12:24 PM
    BlazeAce
    BlazeAce Well-Known Member
    AL
    04 Super White
    This^^^^^
    If you don't gun it all the time, with stock tires I used to get 21 mpg calculated at every fill up. If you want to get extreme, you could try out hypermiling. I can say that you can for sure do better than 25 mpg with those techniques...and it is fun in its own way
  5. Feb 4, 2013 at 12:25 PM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Another thing to factor in is resale in the taco, with the saved miles, you will get more out of your taco when you sell it.
  6. Feb 4, 2013 at 12:28 PM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    I guess only you can answer that question for yourself, since everybodys situration is different. I for one sold my '99 tacoma and went the economical route with a jetta and regretted it after about 3 mos. Then after a year traded the jetta in on a new tacoma. I bought a truck for a reason. TO DRIVE IT.. besides your tacoma is paid for....that should relieve the sting a little at the pump.
  7. Feb 4, 2013 at 1:08 PM
    rangejeep
    rangejeep [OP] Well-Known Member
    Charlotte, NC
    05 Tacoma 4x4 TRD Off Road
    Good advise Chad7088. I forgot what it was like when I drove a Dodge Intrepid for a 5+ years. Driving enjoyment was just about a ZERO (sorry if you're an Intrepid fan; they just suck!). I know a little car 3 inches off the ground will not have the same driving enjoyment or stability as a Tacoma. I also realized my 6'6" body might not fit in a Civic. Even if it did I'll have to roll out of car to get out. My lower back will be killing me by end of the week.
    Could be forced into this when gas is $8 a gallon.
  8. Feb 4, 2013 at 1:29 PM
    DirtDriven
    DirtDriven Active Member
    Just read the title of the post and thought I would chime in since I am in the exact same situation. The short answer is yes. I live about an hour from work and have to commute back and forth. I had a chance to buy a used 02 Civic and like you was wondering if it would be worth buying to save on gas. I sit down and done some math and figured out that it would take me about a year or a little less to be at the break even point on buying the car vs the gas savings. It is going on two years now and it has worked out great for me and also helps to keep the miles off my truck.
  9. Feb 4, 2013 at 1:31 PM
    Davtopgun
    David
    Central Alabama
    I'm 6'4" myself, and I avoid cars for the very reason of having to crawl in and out of it.
  10. Feb 4, 2013 at 2:19 PM
    toys4ever
    toys4ever Well-Known Member
    PA
    01 4x4 4-banger stick
    Civic's and Tacoma's belong together, I had 3 different combo's of the sort over the years... When I get a different tacoma I get a different civic or vice versa.
  11. Feb 4, 2013 at 2:23 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    My thoughts exactly but there is more to consider. The civic will not be worth little to zero as the cost of fuel will always fluctuate above its current average and there are always people looking to travel this similar path. It won't be worth 3k obviously but if you could make half the money back as long as the car does not self destruct in the meantime. Then of course you have a car that is truly nothing and you hope its demise occurs after you break even.
    Also, another thing to consider is the Tacoma will not be depreciating as fast due to the lack of usage as a DD. This can be beneficial as Tacomas hold their value.
    The biggest issue to get over(for me at least) as the civic will nowhere be as enjoyable to drive on a daily basis as the Tacoma. As long as you can get from point a to point b and not care how it happens then a cheap dd may be worth it.
  12. Feb 4, 2013 at 2:31 PM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    Lots to come
    OH geez....yea you forgot to mention you were 6'6"....the civic would NOT be your friend!:D
    As a matter of fact after you roll out of it...you will probably kick it!
  13. Feb 4, 2013 at 2:36 PM
    kryten
    Canada
    Fit = go cart :D
    At least that is how I remember it from my test drive back in '07. Was a 5spd though...
  14. Feb 4, 2013 at 2:49 PM
    kryten
    Canada
    No, no. I meant that in a good way. :)
    I was test driving with my dad and we were both gone for over an hour, not in any rush to return to the dealer. It was a fun little car. I agree, would rather have one over a Civic.
  15. Feb 4, 2013 at 2:49 PM
    #35
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Maintenance on the car is really NOT an added expense, only the initial purchase price plus its taxes and the added insurance are. Any maintence expense to the car is saved maintenance expense for the truck, and civics are a bit cheaper to maintain than tacomas in my experience. Tire costs alone are about 1/2.
    Of course, if you truck sits so much that the servicing gets done by time, not milage, or the tires dry rot before wearing out, then yes, there will be some additional expense.
    Without actually doing the hard math and knowing how to predict gas prices for the future, I bet you'd roughly break even, with more hassle. I miss my '96 civic sometimes though, consistantly better than 40 mpg (us) on my previous hwy commute.
  16. Feb 4, 2013 at 3:59 PM
    #36
    jimlindenfelser
    jimlindenfelser Active Member
    Jim
    Greenacres, WA
    05 DCab TRD
    The way I look at it, I put 55,000 mi on my corolla since i bought it, not on my truck. Plus over twice the mpg.
    But I don't really care much about the enjoyment of driving back and forth to work. it is a boring drive no matter what. Maybe if I had alot longer commute.
    I love driving my carolla knowing for $2000.00 i have a car that is going to last me a lot longer with little maintenance or repair costs.
  17. Feb 4, 2013 at 5:19 PM
    #37
    TRD Toy85
    TRD Toy85 Well-Known Member
    CT
    loaded 2013 TRD sport
    I commute very far to work , and I get dirty as hell in my trade .
    A work beater is a must have for me.
    I have a 97 civic as a commuter car, my taco is a garage queen.
    Well worth it for me.
  18. Feb 4, 2013 at 5:37 PM
    #38
    Kailey Jo
    Kailey Jo Well-Known Member
    Liam
    Ontario
    09 Access Cab TRD
    Swap the civic for a bike:
    -Better mileage
    -More fun
    -Profit!
  19. Feb 4, 2013 at 7:25 PM
    #39
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I will be doing something similar. More than $3k though. I'm a construction electrician and end up on sites that easily have me driving over a 100 miles a day. In my tacoma that's a fill up about every 2.5 days plus over 2000 miles a month. So for me it's cheaper to have a fuel efficient vehicle, along with my truck lasting longer from not putting so many miles on it.
  20. Feb 5, 2013 at 5:39 AM
    #40
    rangejeep
    Charlotte, NC
    Kailey Jo - You're brave to ride a bike living in Ontario. I can only imagine the Harsh winters!!!
    I'm saving for a classic muscle car and by no means ready to buy or have the money for it. But if I get a used modern classic NOW it might be worth getting. It will need to be 4 door, $10k or less, 30+MPG, and fun to drive. Like a Acura TSX, BMW 3, Mazda 3, Civic SI, or Jetta GLI. A fun car to whip through application mountains roads with the family.
    As I think about it more, I'll eventually get bored with the 4 door sporty car and go back to the muscle. I'm drooling just thinking about resto mod by Detroit Speed. Or even a killer 1973 K-5. Shoot...I'll even take a CJ7 with 350 swap.
