Keep Warping Brake Rotors Help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by steaktacos, Jan 6, 2020.
  1. Jan 8, 2020 at 8:57 AM
    #41
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I have a craftsman, and it's worked pretty well for me. Don't use it a ton, but my crank pulley hasn't fallen off yet, lol.
  2. Jan 8, 2020 at 7:34 PM
    #42
    tsb
    tsb 2018 National Champions
    Clemson Tigers
    '14 4X4 DBCSB TRD OR
    N-FAB nurfs, ARE cover, Gentex mirror, 20% tint
  3. Jan 8, 2020 at 7:36 PM
    #43
    tsb
    Clemson Tigers
    DOT Pad Codes
    This two letter edge code mandated by the DOT, and painted on all street legal brake pads, will give you some indication of their ability to resist fade. But only if you know how to read them. However, because of the wide range involved in each letter, it is only a rough indication.
    Explanation of D.O.T. Edge Codes Located on all Brake Pads
    Official D.O.T. Edge Code
    Coefficient of Friction (C.F.)
    @ 250 F and @ 600 F
    EE
    0.25 to 0.35 both temps
    0-25% fade at 600 F possible
    FE
    0.25 to 0.35 @ 250 F
    0.35 to 0.45 @ 600 F
    2% to 44% fade at 600 F possible
    FF
    0.35 to 0.45 both temps
    0-22% fade at 600 F possible
    GG
    0.45 to 0.55
    Very Rare
    HH
    0.55 to 0.65
    Carbon/Carbon only.
    O.K. up to 3000 F where it glows
    Notes: These edge codes are located on the edge of the friction material of every brake pad by government regulation, along with some other codes. The first letter is a grading of the C.F. at 250 F and the second letter is a grading of the material at 600 F. Each letter grade can actually have quite a range of C.F. But a difference in the letter grade from medium to hot temperature could be an indicator of fade. The letters can be in any order. Therefore FE pads fade when hot, and EF pads would not grab when cold.. Also, you should know that Steel on Steel has a C.F. of 0.25!! So EE pads have only marginally more torque than no pads at all! Therefore FF pads are usually considered the minimum for a high-performance pad.
    matches3215 and CS_AR like this.
