keeping a double din from bouncing around?
Discussion in 'Audio & Video' started by eric3187, Jul 16, 2012.
  1. Jul 16, 2012 at 11:15 PM
    eric3187
    eric3187 [OP] Well-Known Member
    so i installed my double din the other day using factory brackets... now that i am in a living situation where i ride poorly maintained dirt/rock roads and washboard gravel roads, the screen bounces around a lot to the point of making lots of noise...
    are there any fixes to this? i imagine once i start off roaring out here, it will only get worse and possibly to the point of falling out..
  2. Jul 16, 2012 at 11:33 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    What model is it? Do you have a pic of which part exactly is loose? The whole unit shakes or just the screen at a certain point, etc?
    More info will be easier to help with, and pictures beats trying to paint one with words.
  3. Jul 16, 2012 at 11:37 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    It shouldnt move at all. Has to be improper installation. The only other thing could be lose screws on your mounting brackets or screws not in the proper position... I guess that would fall into the improper installation category though :notsure:
  4. Jul 16, 2012 at 11:49 PM
    pinktaco808
    pinktaco808 Hot Steppa
    mine too, but because my bass is so dam loud
  5. Jul 17, 2012 at 12:12 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Tighten it down...
    Or maybe take the HU out put Velcro around the edges and reinstall
  6. Jul 17, 2012 at 12:16 AM
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    Mine has the same problem, when offroading it shakes a lot to the point of the plastic around getting out
  7. Jul 17, 2012 at 12:18 AM
    ProForce
    Anthony
    Alaska
    This should not be happening, no matter what kind of bass you have :eek:
  8. Jul 17, 2012 at 9:24 AM
    eric3187
    its a kenwood dnx6990hd. the whole unit bounces around, i guess i can pull it out to re-tighten the mounting brackets. ill try to get a video of it later today.
  9. Jul 17, 2012 at 10:40 AM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Find out where the loose points are and see what you can do to either tighten some screws or place a spacer between of sorts, such as the velcro mentioned above. Your first step is going to be finding the source of the problem
  10. Jul 17, 2012 at 10:43 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    My pioneer does the same thing. I think the only way to keep it from shaking is custom brackets. The weight of the stereo is too much for the cheap brackets.
  11. Jul 18, 2012 at 6:59 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    Did you put any washers on the screws that to into the side of the Kenwood? Sometimes the head of the screw will try to pull through the plastic.
  12. Jul 18, 2012 at 1:40 PM
    eric3187
    no washers, i will have to pull it out to double check everything once this rain stops
  13. Jul 18, 2012 at 1:44 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i had thqt problem with the metal factory brackets, went with the plstic brackets with the scosche that i had before and the bouncing went away
  14. Jul 18, 2012 at 1:50 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    where did you get those brackets? I have the same problem with my sony double din
  15. Jul 18, 2012 at 3:10 PM
    Aw9d
    Aw9d That one guy
    I have the scosche kit which uses plastic brackets, I can go off road and my DVD player never jumps at all. I think I need to see a pic of these brackets you have.
  16. Jul 18, 2012 at 3:19 PM
    tacomonazul
    Luis
    SOCAL
    07 DCSB LT/4LINK
    They are the factory ones from the factory unit, they are like metal
  17. Jul 18, 2012 at 3:36 PM
    Aw9d
    Aw9d That one guy
    The only 3 reasons that the metal ones should bounce around (I used the metal ones first until I realized the viewing angle was shit and didn't want to drill).
    1. You only put 1 screw on each side. The deck needs 2 screws on each side as a minimum.
    2. Screws fell out that held the deck in place or the brackets in place.
    3. God hates you.
  18. Jul 18, 2012 at 7:52 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    God hates me apparently. And mine only rattles when I Offroad but more than I like
  19. Jul 18, 2012 at 8:55 PM
    eric3187
    are the plastic ones provided with a socshe kit better than the factory ones?
  20. Jul 19, 2012 at 11:23 AM
    Aw9d
    Aw9d That one guy
    Yes and no.
    They are plastic, not metal..
    however
    The metal ones will give you a horrible viewing angle with any DVD player in the truck. The Socshe will correct that issue. You could also drill new mounting holes into the metal brackets. But if bouncing is an issue, I'd get a Socshe kit. Mine doesn't bounce even when wheeling.
