Keeping AC Condensation Drip off Frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by hiroze, Aug 22, 2013.
  1. Aug 22, 2013 at 8:47 AM
    hiroze
    hiroze [OP] Member
    Raleigh, NC
    02 Tacoma 4x4 TRD SR5
    Hiya hiya:
    Recently (past few days) I had water pooling and dumping into the floor of the cabin from a clogged AC drain hose. Cleared the drain hose and now the leak is coming out from under the car, which seems to be normal based on 1st and 2nd gen threads I've read about this issue. I also moved from CA to NC in the past week so the humidity went up 40% and very likely contributed to it.
    I'm not sure about the newer models, but on my 2002, the drip seems to fall onto the frame (will have to confirm on the weekend when I can take a good look), which seems like it could be a long term problem brewing. I'm sure there's an easy fix to keep the water off the frame and I'm hoping people could give me a few good/easy suggestions if anyone thinks it's necessary? I saw a solution or two here, but am hoping for more options if possible.
    Also, on a much less important, general curiosity note- is there not a fix to this problem in the manufacturing process? Given some of the amazingly advanced technology, this seems like it would have a fix regardless of weather conditions.
  2. Aug 22, 2013 at 3:48 PM
    hossmaster
    hossmaster Well-Known Member
    League City, Tx
    2002 Converted / 2017 OR
    Was a PreRunner, now it isn't
    just add a rubber hose on the drain and make it long enough to go below the frame and zip tie it to something there.
  3. Aug 22, 2013 at 3:54 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    Mine drips off onto something really hot cuz I hear it "sssssssss" after a long summer day of driving with AC on full blast. But I don't see any rust so I'm not sure what it is
  4. Aug 22, 2013 at 4:17 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    ^ the cat!
  5. Aug 22, 2013 at 4:17 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    exactly what I did too
  6. Aug 23, 2013 at 12:13 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Has your truck never driven in the rain or through a puddle either? The frame is gonna get wet regardless, I wouldn't worry about it.
  7. Aug 23, 2013 at 12:45 PM
    TIPICOTACO
    Tyler
    nw nj
    considering frame rust is such a HUGE well known problem w/ these trucks I'd say any little bit helps
  8. Aug 23, 2013 at 1:14 PM
    Changeling
    Changeling Well-Known Member
    Maryland
    2001 Tacoma TRD SRD V6 X-Cab Limited Edition
    I agree totally with you about fixing a problem with the water, just common sense!
  9. Aug 23, 2013 at 1:32 PM
    MowTaco
    Kansas
    Whatever tickles your pickle I guess. I've lost hope for mine and am just hoping it'll rot out by 2019 so I get a new one
  10. Aug 23, 2013 at 3:27 PM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    I gotta go with Batman here... the frames rust from the inside out because the 'C' channels were layered on top of each other setting up no conclusion but rust. Think back to those earlier generation 1979-1994 trucks that were in mint condition except over the rear wheels. Toyota lap welded 2 pieces together here and every one of them rusted from the inside out. Your driving in the rain will get the frame wetter than the condensate. Too bad Toyota engineers failed to remember this earlier debacle?
  11. Aug 23, 2013 at 3:38 PM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    The water that builds from AC condensation doesn't contain impurities that would do damage to steel of the frame.
  12. Aug 25, 2013 at 1:49 PM
    hiroze
    hiroze [OP] Member
    Raleigh, NC
    Thanks for all the tips and info! As mentioned by others, I'd like to minimize any wear on the frame due to the trouble frame rust can cause. Plus, it's an easy fix so why not do it right?
