keeping airconditoning running when you are outside the locked vehicle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skweezal, Jun 28, 2010.
  1. Jun 28, 2010 at 1:54 PM
    skweezal
    skweezal [OP] Well-Known Member
    It's hot outside and i travel with my dogs. I sometimes have to keep the AC on for them but am unable to lock the doors when I am outside the vehicle. I really dont like to leave the vehicle running and unlocked!!
    Is there any way to over-ride this issue?
    thanks
    sk
  2. Jun 28, 2010 at 1:57 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Or remove cooling system out of portable cooler and run that, mounted to the back window :D. No need for running engine just tow battery.
  3. Jun 28, 2010 at 1:57 PM
    StandingCow
    StandingCow Well-Known Member
    NJ
    09 SR5 4x4 V6 access cab
    Pretty sure you gotta keep it running, but you could bring a second key with you so you can at least lock the doors.
  4. Jun 28, 2010 at 1:58 PM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    15 DC V6 4x4 TRD Magnetic Gray
    High-flow coconut smiley-face air freshener.
    x2, spare key and lock the doors.
  5. Jun 28, 2010 at 2:06 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You could probably do it with a remote start... dunno if the timer is variable but I think most will run about 20min. This way, there's no key in the vehicle, if they attempt to put it in gear the immobilizer will kick in... better theft deterant. Leaving the key in the ignition even with the doors locked is still screaming for someone to take 2 seconds to break the window and drive off all in about 5 seconds.
  6. Jun 28, 2010 at 2:10 PM
    skweezal
    wow..thanks for all the speedy replies!! I thought I had tried the second key thing, but will try it again. THe locations I travel to are relatively safe (large equestrian centers etc), so not just on the street. I'd think (hope) the likelihood of someone breaking in to a locked/running vehicle when there are alot of other people around is less in a situation like this, but then again, never underestimate the stupidity or boldness of criminals!!
    Again, thanks from me and my pups! :)
  7. Jun 28, 2010 at 2:12 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    this...but...when im working i keep 2 sets of keys on me for my patrol car...1 in the ignition running and 1 in my pocket to lock and unlock
  8. Jun 28, 2010 at 2:32 PM
    bagster
    bagster Well-Known Member
    Just get some meaner dogs.
  9. Jun 28, 2010 at 2:46 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    x 2
  10. Jun 28, 2010 at 2:54 PM
    Everbody
    Everbody Well-Known Member
    Central CA
    05 PreRunner SR5 TRD 2wd
    Looks stock
    ...have special equipment to keep the AC on and will page an officer if the engine quits for any reason. www.officer.com is a start.
  11. Jun 28, 2010 at 3:06 PM
    kwalton
    kwalton Well-Known Member
    Baltimore, Md
    2017 MGM DCSB Sport 4x4
    X2 for the remote starter. It's always the first thing i install on any of my vehicles.
    On another note you may want to check your local laws about leaving keys in running vehicle while unattended. My mom received a $50 ticket when her car was stolen out of her front driveway while she was warming it up in the winter. Talk about adding insult to injury...
  12. Jun 28, 2010 at 3:11 PM
    JKD
    JKD Well-Known Member
    Put your key and your lock remote on a keyring with one of those disconnects on it.
    Leave the key in the ignition. Take the remote. Close door. Lock with remote.
  13. Jun 28, 2010 at 3:20 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    I Had the Dealer Slap In An AutoMate AM-7, Alarm/Remote Start. The Above Posts are Correct, Times Out After 12 or 20 Minutes, But Can Be Locked, Armed, And Left Running.
    I Have A Clifford G-4 In My Solara. Will Automatically Start on (Adjustable) Low Voltage or (Adjustable) Low Temperature. Don't Think It Will Start on High Temp, But I'd Have To Check. It Will Run for Hours If I Program It That Way. Whole System LapTop Programmable. SPENSIVE TOO !!!
    The Technology Is Out There. Post #10 Looks Like a Great Idea.
    I've Heard About Site Called "Googley" or Somthin'. Might Try That
  14. Jun 28, 2010 at 3:45 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    x3
    park, shut off veh, get out with keys
    use starter, veh locks, heat/air conditioning is just as you left it.
    best option the truck has
  15. Jun 28, 2010 at 6:38 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Yes, this is illegal in the surrounding counties where I live.
  16. Jun 28, 2010 at 6:53 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    get bigger meaner dogs or move to a good neighborhood
  17. Jun 28, 2010 at 6:58 PM
    747
    747 function > form
    1st Gen.
    I've received a ticket for an unattended vehicle also. For me, it probably didn't help that when the LEO was explaining to me that unattended vehicles lead to auto theft, I replied: "Poor police work leads to auto theft." Ooops...:D
