Keeping dogs cool
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wyllie, Aug 7, 2022.
  1. Aug 7, 2022 at 2:11 PM
    Wyllie
    Wyllie [OP] New Member
    Lauren
    Question for anyone who travels with their dogs.
    I have a 2018 Tacoma and a Leer camper. I got the shell in hopes of transporting all my dogs for hiking/camping/fishing trips since they don’t fit in the backseat. But in 106 degrees I need a way to keep them cool back there.
    Any companies, DIY, or ideas anyone has for keeping dogs cool in the back would be appreciated.
  2. Aug 7, 2022 at 2:28 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Crack open the rear window/rear side windows. The breeze should be fine.
  3. Aug 7, 2022 at 2:38 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Crack the slider windows on the camper shell. You can also buy a fan or fans and plug them into the power plug located in the bed. If you don't have one, you can find solar powered fans. Mount the solar panel on the roof of the camper shell and run the wire inside the cab to the fan(s).
  4. Aug 7, 2022 at 2:42 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    uploadadventure likes this.
  5. Aug 7, 2022 at 2:42 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Above ideas are good if you have a slider window in the shell. Also add a seal of some sort between the cab and shell window to increase airflow from the cab - cheapest would be a rectangular frame you make with pipe or pool noodles wedged in there…
    Don’t run your A/c on max and don’t use recirculate if you do this without a fan system for the shell- you won’t get positive pressure in the cab forcing cool air into the shell if you do- has to be set to fresh air, not recirculate.
  6. Aug 7, 2022 at 3:00 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Keep them in the cab.
    MDFM31, stftaco, RIX TUX and 5 others like this.
  7. Aug 7, 2022 at 3:13 PM
    OnHartung'sRoad
  8. Aug 7, 2022 at 3:14 PM
    OnHartung'sRoad
    Yeah it’s the best option and I do it also, but as OP mentioned, some people can’t due to their pet’s size or number… Help with suggestions for what she has.
    Tiny's Taco likes this.
  9. Aug 7, 2022 at 3:24 PM
    OnHartung'sRoad
  10. Aug 7, 2022 at 3:25 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Do you have to take all of them?
    TexasWhiteIce likes this.
  11. Aug 7, 2022 at 3:29 PM
    OnHartung'sRoad
  12. Aug 7, 2022 at 3:30 PM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    I assume that she's considered this option.
    I also assume she's asking because she would like to.
    TDImark and OnHartung'sRoad like this.
  13. Aug 7, 2022 at 3:48 PM
    OnHartung'sRoad
    Also- is your shell insulated? I have an RTT
    on my truck and it’s like parking in the shade, but a uninsulated shell gets really hot from the sun. And think about insulation on the floor, if the air temp is hot, so will be the floor.
    Also get side window pet screens if you don’t have them, they are heavy duty screens and the pups and cargo can’t rip them so you can leave the windows open a bit for extra ventilation.
  14. Aug 7, 2022 at 3:58 PM
    xndak
    xndak Well-Known Member
    2023 Off Road
    Where do you live? How hot of temps will you be traveling in ? Very dangerous for dogs in back anytime you have to slow down, stop, turn, accident, etc quickly - they just become a pinball at that point . I agree with crispytacolover - cab is best option
  15. Aug 7, 2022 at 4:06 PM
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    My shell keeps the bed area cooler than the cab. Of course AC in the cab wins. I keep my dog, 85lb Pyr, in the back seat but in the bed with windows open would be okay while moving but doesn't seem real safe for the dog.
    While stopped like running into a store, does anyone know if the engine would keep running if you left it on for the AC? I did it for about 2mins once and seemed like it might but I don't think the door would lock but can't recall exactly. Next time I'm out I can test it.
  16. Aug 7, 2022 at 4:13 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I wish I knew a better solution. DC powered Aircon is crazy expensive, like 2 to 5 grand expensive.
    With the summer heat, my dogs ride in the cab. If they couldn't I would postpone their travels for fairer weather.
  17. Aug 7, 2022 at 4:59 PM
    CrispyTacoLover
    Then google search truck bed air conditioner.
  18. Aug 7, 2022 at 6:10 PM
    OnHartung'sRoad
    Those require a lot of amps, the smaller ones @75 amps, it sounds like a good idea if she has an extra battery setup for it. The alternator will be running a lot as well but it could handle the load. Definitely have a backup second battery for the truck.
  19. Aug 7, 2022 at 6:40 PM
    CrispyTacoLover
    https://www.icybreeze.com/buy-icybreeze-platinum/
  20. Aug 7, 2022 at 7:16 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Inside a canopy is like a oven when it's that hot outside. Keep the dogs in the air conditioned cab with you... if you have too many leave 1 or 2 at home and take them on your next adventure.
