Keeps getting worse continued
Discussion in '1st Gen. Tacomas (1995-2004)' started by Notamechanic80, Oct 2, 2017.
  1. Oct 2, 2017 at 2:16 PM
    Notamechanic80
    Notamechanic80 [OP] Member
    Ira
    1996 Tacoma 2.7
    Continuing from my last thread that I was unable to find. Finally got the cylinders tested. 1,2 over 60 3 around 30 and 4 less than 10. Found a 2001 that had been rolled with a newer motor for sale. Grabbed it up. Same engine (2.7 3rzfe) but the 1996 is distributor and the 2001 is coil packs. My question is do I need to replace every wire in the 1996 with the wiring from the 2001 to get the computer to work? I'm 3 days into trying to get every wire disconnected without breaking anything. I'm out of cash so buying expensive adapters isn't going to happen. Hoping I can find a way to make things easier. Thanks.
  2. Oct 2, 2017 at 2:33 PM
    Notamechanic80
    Ira
    1996 Tacoma 2.7
    Thanks. I copied over to there. I'll delete this.
  3. Oct 2, 2017 at 2:35 PM
    eon_blue
    Azusa, CA
    I think he was just posting your former thread in here for others to reference in case they had any experience/advice to relay. This thread presents a new issue so I don't think you need to delete it (only mods can delete threads anyhow)
