Keg Carbonation
Discussion in 'Homebrewing' started by TEX82Trooper, Mar 3, 2012.
  1. Mar 3, 2012 at 10:25 AM
    TEX82Trooper
    TEX82Trooper [OP] Outdoor Adventurer
    Las Cruces,NM
    '06 Tacoma TRD Sport camping & hunting rig.
    mild lift (3 inch?) of unknown origin (truck was bought used),much more to come.Self-fabbed rock-rails.
    Hey all,
    I usually keg in 5 gal corny kegs and force carbonate for the sake of time, but have wanted to try naturally carbonating in the keg for a while now. I tried with the red ale I finished up a couple weeks back, but it didn't carbonate, so I wound up force carbonating it anyway. Wound up with the ale cloudy instead of nice and clear as it was when I kegged it. Other than adding in the priming sugar, what am I missing? Any tips or advice would be appreciated.
  2. Mar 3, 2012 at 10:30 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Good question. I always bottle my 5-gal batches, using corn sugar to promote krausening. With a keg, I don't know what the dynamics of the secondary fermentation would be. Subbed for answers!
  3. Mar 3, 2012 at 10:36 AM
    TEX82Trooper
    Las Cruces,NM
    Paul,
    I gave up bottling after brewing for only year, got tired of crates of bottles stacked up in my apartment and the hassle of sanitizing them. Plus it's nice just pulling a tap handle for a nice cold home brew. My beer fridge holds 2, 5 gallon kegs with taps in the door and 3 cases of bottles.
  4. Mar 3, 2012 at 10:39 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Of course you need some viable yeast in the keg for priming sugar to work, did you get it to clean?
  5. Mar 3, 2012 at 10:39 AM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    I hear you. I'm gonna have to read up on in-keg carbonation. From the little bit of knowledge I have, it seems like the pros all use some kind of CO2 injection.
  6. Mar 3, 2012 at 10:43 AM
    worthywads
    Heilemann's Old Style and Special Export claimed "Krausened" and they did do a 10% active ferment blended into finished beer, but it was always rather a gimmick and they topped off with forced carbonation like everyone else.
    Sierra Nevada technically calls their beers bottle and now can finished but the amount of carbonation derived is tiny vs forced carb.
  7. Oct 1, 2014 at 5:25 PM
    yowow
    yowow Well-Known Member
    Make sure any natural carb. in kegs have a good pressure relief valves. Cornie kegs are good, as long as it's not one of those one time only pressure valves. Best to play it safe. Pepsi kegs are at 90 psi I believe. Coca-Cola kegs have the one time use safety valves. Please correct me if I am wrong.
    I ferment with cornies and transfer to Sankey kegs then force Carbonite. And yes, I bought them brand new from the manufacturer. They are not 'rented'.
    The cornies, I have the co2 plugged into a blow off tube. Works great. Then I can transfer to the keg with c02 pressure.
  8. Oct 1, 2014 at 5:28 PM
    T4RFTMFW
    T4RFTMFW Report Undocumented Feelings
    Kyle’s mom
    Never seen a Cornelius keg with a single use pressure release valve before.
  9. Oct 1, 2014 at 5:30 PM
    T4RFTMFW
    Kyle’s mom
    Pic of this? Do you have ball lock kegs or twist lock?
  10. Oct 1, 2014 at 5:41 PM
    yowow
    Ball lock kegs. Then I transfer to 8 or 15.5 gallon Sankey kegs
    Pin lock has 'fuse' type pressure release valves. Pin lock is Coca-Cola kegs
  11. Oct 1, 2014 at 5:43 PM
    T4RFTMFW
    Kyle’s mom
    Oh okay. I couldn't tell if you had those fittings or not.
    Nice and clean! :thumbsup:
  12. Oct 1, 2014 at 5:47 PM
    yowow
    From keg connection website. Once the pressure valve is used, you need to replace it.
  13. Oct 1, 2014 at 5:57 PM
    T4RFTMFW
    Kyle’s mom
    Interesting, thanks. I would probably use a different lid altogether with a normal PRV.
