Kelford cams GB feeler
Discussion in 'Group Buys' started by FreidTaco, May 3, 2016.
  1. May 18, 2016 at 8:51 AM
    FreidTaco
    FreidTaco [OP] boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Bump for interest.
  2. May 18, 2016 at 10:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I'd like to see their dyno charts. Unfortunately, my friend's 1GR build is on hold. For a few weeks, while he works on another project. We have before dyno's of his truck though. So his will be easy.
  3. May 18, 2016 at 11:55 AM
    FreidTaco
    jeff
    I am working hard to get graphs. He is double checking all of his stuff. I know people out there want more power!
  4. May 21, 2016 at 8:11 PM
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    With these cams and head work and 11:1 compression pistons at .5 over how much extra power would one expect? Can't afford it right now but I wouldn't mind more power one day soon... Also be adding a uconn
  5. May 22, 2016 at 10:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Who has an engine like that?
  6. May 22, 2016 at 11:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I know that the simulator projects roughly 400 bhp with the L132X cams, oversized supertech valves, and stock bore.
  7. May 22, 2016 at 12:07 PM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Well it would be the engine I'd build if I could afford it but I'm planning on eventually building it like that or somewhat close
  8. May 22, 2016 at 12:11 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Ok. You must have meant .050" over, and not .500" over.
  9. May 22, 2016 at 12:13 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Going that far over from stock, means sleeves. No way around it.
  10. May 22, 2016 at 12:17 PM
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Whoops yes that's what I meant!! Wouldn't be doing sleeves unless I was going to do stroker but that won't happen :p
  11. May 25, 2016 at 7:02 AM
    FreidTaco
    jeff
    Well seeing as there was so little interest for this without graphs, i was able to work a deal on 2 sets so we can get them to the us and put down some numbers and try again. If you are willing to make some dyno runs he will do 1200 per set. Pm me if you are wanting on the this dyno run list.
  12. May 26, 2016 at 3:01 PM
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Would any of these cams work without head work? @Torspd
    And any word on the dyno graph?
  13. May 26, 2016 at 5:10 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The ones with the p/n L132x "should" require no head workon an '05+ single VVT-I 1GR. Springs must be replaced though.
  14. May 26, 2016 at 5:11 PM
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hmmm "should" doesnt sound good
  15. May 26, 2016 at 5:14 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Only ones that those have been tested on are an '03-'04 1GR, from a 4Runner, that I am aware of. Locally at least.
  16. May 26, 2016 at 5:14 PM
    #36
    GT7
    Grant
    Phoenix
    2013 DCLB
    And wouldnt you have to replace rocker arms too?
  17. May 26, 2016 at 5:16 PM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There aren't any. Just cam on bucket.
  18. May 26, 2016 at 5:18 PM
    #38
    GT7
    Grant
    Phoenix
    2013 DCLB
    Ok thanks alot tor, any other things to be aware of? Would it be too much for stock drive line components?
    Thanks
    Grant
  19. May 26, 2016 at 5:24 PM
    #39
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
  20. May 26, 2016 at 5:26 PM
    #40
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not one bit.
