Kelford cams GB feeler
Discussion in 'Group Buys' started by FreidTaco, May 3, 2016.
  1. May 26, 2016 at 5:28 PM
    #41
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    What would I really expect to gain? Im getting the ucon with in the year and i would do these when I do the cam gears
  2. May 26, 2016 at 5:29 PM
    #42
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    Could Torspd be a liaison to XRU to try and get some more people? I know they are always chasing power over there.
  3. May 26, 2016 at 5:40 PM
    #43
    snowtank
    snowtank Where the fuck did my beer go!
    Andrew
    Arizona
    11 txpro dcsb 08 trd sprt dcsb
    Some stuff here and there....
  4. May 26, 2016 at 5:40 PM
    #44
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    What about Steven?
  5. May 26, 2016 at 5:41 PM
    #45
    snowtank
    Andrew
    Arizona
    That guy needs no more power right now haha. We are still finishing up everything on our plate to get his truck ready for him by the time he gets back soon
    The Fluffer[QUOTED] likes this.
  6. May 26, 2016 at 5:48 PM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    It would mean using the stock cam gears with the cams.
  7. May 26, 2016 at 5:48 PM
    #47
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Already did. :thumbsup:
  8. May 28, 2016 at 9:29 AM
    #48
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
  9. May 30, 2016 at 5:09 PM
    #49
    GT7
    Grant
    Phoenix
    2013 DCLB
    Any way to find out what the gains could be?
  10. May 30, 2016 at 9:26 PM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When my friend gets his engine finished, that will be the closest engine to stock, with cams, that we'll have for comparisons.
  11. Jun 17, 2016 at 5:03 AM
    #51
    HectoRome
    HectoRome Playing Scientist In The PNW
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs, Archive Garage Shackle Flip
    59926P ICON 2.5 Remote Reservoir Front Coil Over Shocks 56103 Icon Rear Hydraulic Bump Stop Kit K53163 Icon RXT Leaf Springs Kit 58730 Icon 2.5 Front Remote Reservoir Coil overs 59926P Icon 2.5 RXT OMEGA Remote Reservoir By-Pass Shocks 58550 Icon Billet Aluminum Upper Control Arms Dirt King Steel Lower Control, 1” Uni-ball Joints Archive Garage Rear Leaf Spring Shackle Flip Kit TRD Cat Back Exhaust TRD High Flow Air Filter Kenwood Receiver + JL Audio Speakers Extended Stainless Steel Front Brake Lines Extended Stainless Steel Rear Brake Lines Electronic Locking Rear Differential Rigid LED Driving Lights LED Bar in Bumper Top Windshield LED Bar Custom TACOMA Raptor Grill w/ LED Running Lights METHOD Standard Matte Black Wheels
  12. Jun 17, 2016 at 8:45 AM
    #52
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Believe all you need to do is upgrade to stiffer valve springs
  13. Jun 18, 2016 at 2:07 AM
    #53
    HectoRome
    Sweet, so torque gains and different (better or worse, hopefully better) gas consumption rates and wider / sooner power band are going to be a given.
    What type of HP Gains we potentially looking at here after a good tune ? ? ?
  14. Jun 18, 2016 at 8:12 AM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Slapping them into the engine, is a teeny tiny understatement.
    To quote myself.
    You'll have to replace the valve springs. It can be done with the engine in the bay. There are tools and methods to do so. Or pull the heads and swap the springs on a table. I purchased a freaking awesome tool to release the retainers. I can share that if need be.
    Then, you need to verify valve lash between the cam and bucket. To make sure that the gap is of the proper tolerance.
    To do the intake cams, means removal of the timing cover.
    A lengthy project, to speak honestly.
    To simplify things, which I mean by keeping the same base circle ( which means that your valve lash should theoretically not change, and swapping buckets won't be necessary) send the cams into Kelford. Have them rework them to the specs we have listed here. Then they would be more "drop in."
  15. Oct 3, 2016 at 1:33 AM
    #55
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Spoke to someone on IG who got in contact with kelford in Feb this year. he said they gave him no problem as far as making custom cams. Cost is about $1162 USD. I wonder if their contract expired with subzero?
  16. Oct 3, 2016 at 8:20 AM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Custom is probably different than non custom?
