Kelford Cams GB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by modifyd!, Jan 16, 2023.
  1. Jan 24, 2023 at 5:36 PM
    #41
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Absolutely, count me in
  2. Jan 25, 2023 at 9:39 AM
    #42
    prise
    prise AZ's Toaster Strudel Low T Andrew
    Prise
    Rally Runner 04 GX470
    Need to put in a new engine so I guess the timing works out. Couple of questions though;
    What kinda price
    If I went with the 234-A and say wanted to supercharge it three years down the road would I need to take that back out for the stock or SC version?
    TodayWasTHeDaY likes this.
  3. Jan 25, 2023 at 9:55 AM
    #43
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    Group buy price last time was approx $1500 shipped USD for all four camshafts, springs, washers, and retainers.
    TodayWasTHeDaY and BassAckwards like this.
  4. Jan 25, 2023 at 10:05 AM
    #44
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Besides the pain of installing any other issues or considerations on these? you know me more mods more power, lets go. its tempting.
  5. Jan 25, 2023 at 10:33 AM
    #45
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I imagine that's a question you should ask Kelford about. Don't think there'd be an issue running the 234-A if you supercharged down the road but it probably wouldn't be optimized for the supercharger. That's my guess.
    Athlaos likes this.
  6. Jan 25, 2023 at 10:45 AM
    #46
    Athlaos
    Leigh
    Edmonton
    No other issues, I have proven that the retard gears work fine as well. Been 3.5 years that I've had the cams in, and no problems.
    I can certainly give you some advice on install. I made my own spring compressor!
  7. Jan 25, 2023 at 10:56 AM
    #47
    Athlaos
    Leigh
    Edmonton
    FYI time to install was probably 4 hours to take top end apart, 45 mins per spring replacement (got to be super careful) 3 hours to put everything back together, and 30 mins or so to confirm timing. I did not take the timing cover off. So 26 hours.
  8. Jan 25, 2023 at 10:58 AM
    #48
    Athlaos
    Leigh
    Edmonton
    @TodayWasTHeDaY we bang this out in a weekend, do you think? You pay for my fuel down there? Haha
    jamesepoop and TodayWasTHeDaY like this.
  9. Jan 25, 2023 at 10:59 AM
    #49
    TodayWasTHeDaY
    Russ
    Calgary
    That actually doesn't sound as bad as I was thinking time wise. :thumbsup:
    Great info!
  10. Jan 25, 2023 at 11:01 AM
    #50
    Athlaos
    Leigh
    Edmonton
    Oh one more thing, if you want to use Kelford's recommended clearances, we check those and then wait for the new lifters to come in - takes a couple weeks o_O but guys here have used stock clearances and it's been totally fine (Kelford's are a bigger gap, so you get extra lift if you use stock clearances!)
  11. Jan 25, 2023 at 11:02 AM
    #51
    nudavinci64
    Robert
    well you keep saying you want to visit california.. might be time to swing by haha. That does not seem too bad just nerve racking. I need to learn how to check and set timing. I have a feeling mine could be slightly off from the factory. This would be also a perfect time to send the blower off to get ported.
  12. Jan 25, 2023 at 11:03 AM
    #52
    TodayWasTHeDaY
    Russ
    Calgary
    I totally would. Food, drink and lodging too.
    I'm still dreaming of building an engine sometime but need more funds so might be waiting for that to do cams.
    Don't know how likely that scenario is so might be fuck it and just fire them in.
    Athlaos[QUOTED] likes this.
  13. Jan 25, 2023 at 11:03 AM
    #53
    nudavinci64
    Robert
    so you need to buy more stuff your saying?
  14. Jan 25, 2023 at 11:09 AM
    #54
    Athlaos
    Leigh
    Edmonton
    You'll still have them when you decide to build an engine!
  15. Jan 25, 2023 at 11:09 AM
    #55
    Athlaos
    Leigh
    Edmonton
    I noticed some timing drift on my truck actually. The chain probably wears over time.
  16. Jan 25, 2023 at 11:44 AM
    #56
    nudavinci64
    Robert
    ya makes sense. When I did my cam gears I could never get the TDC centered but the top ones were lined up and things have been fine. But had me thinking it could be stretched or off.
  17. Jan 25, 2023 at 11:52 AM
    #57
    Athlaos
    Leigh
    Edmonton
    I think "chain stretch" is just "chain wear". The metal itself should not "stretch" over any period of time.
  18. Jan 25, 2023 at 12:07 PM
    #58
    nudavinci64
    Robert
    ah yah who knows me and Kel were chatting on decide to just run with it as the top parts lined up. I have seen recent comments that sometimes it takes a bunch of turns to get all 3 to line up but i have not seen any issues.
  19. Jan 26, 2023 at 5:56 AM
    #59
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A tad messy, but works very well. Once the valve covers are pulled, and fuel pump relay and/efi fuse pulled, then you can simple bump the engine with the starter. Way easier than turning the crank by hand the whole time. Then turn the crank by hand for the final refined alignment.
  20. Jan 26, 2023 at 6:03 AM
    #60
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    From my previous experience with other engines it's also 2/2 weak/bad tensioner and worn/broken guides in engines with variable valve timing. Most of the time the chain is just fine.
