Kelford Cams GB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by modifyd!, Jan 16, 2023.
  1. Feb 23, 2023 at 5:51 PM
    #121
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I will be keeping the stock cams with the maggy and probably building another motor to use the Kelford cams in. Keep us posted on what you hear from them!
    TodayWasTHeDaY likes this.
  2. Feb 23, 2023 at 5:55 PM
    #122
    PhoS
    PhoS Proffauxssional
    PNW
    08 FJ Cruiser
    Contains MSG
    I called Kelford to ask about the grinds the other day. They said that for most pushing up to 600hp the SC cam is g2g, the turbo cam is better for those pushing the limits(SC or not) but will give up some street-ability.
  3. Feb 23, 2023 at 6:34 PM
    #123
    modifyd!
    modifyd! [OP] Active Member
    @Lucario Runner $987 with drop in springs
    Torspd likes this.
  4. Feb 23, 2023 at 8:14 PM
    #124
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Athlaos likes this.
  5. Feb 24, 2023 at 1:59 PM
    #125
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I guess I know what my horsepower goal is now...
  6. Feb 24, 2023 at 2:56 PM
    #126
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Will you be paying cash or credit? :spending:
    TodayWasTHeDaY and JustDSM like this.
  7. Feb 27, 2023 at 6:11 PM
    #127
    modifyd!
    Working on details for next step now.
    TodayWasTHeDaY and BassAckwards like this.
  8. Mar 4, 2023 at 9:31 AM
    #128
    chueflee
    chueflee Well-Known Member
    Chue
    2013 toyota tacoma TRD offroad extended cab 4x4 v6
    afe intake, urd spec u headers, urd y pipe, 76mm throttle body, kelford camshaft, trd supercharger, urd cam gear, urd thermostat, ucon ems, NST pullies, ipt valve body, stoptech disc brake 323mm front, sos rear disc conversion
    Will the URD -3 degree cam gears work with the 1GR 234-SC camshafts
  9. Mar 4, 2023 at 8:17 PM
    #129
    PhoS
    PNW
    08 FJ Cruiser
    Contains MSG
    Use stock gears.
    BillDaCat8 likes this.
  10. Mar 4, 2023 at 11:20 PM
    #130
    chueflee
    Chue
  11. Mar 5, 2023 at 9:52 PM
    #131
    Athlaos
    Leigh
    Edmonton
    They worked fine for me.
  12. Mar 5, 2023 at 9:54 PM
    #132
    chueflee
    Chue
    your using urd cam gears? athlos
  13. Mar 6, 2023 at 12:18 AM
    #133
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I was sooo tempted to get on this again. Kept me from the fine line of dependable when in the middle of nowhere mod or not.
    jamesepoop likes this.
  14. Mar 6, 2023 at 5:59 AM
    #134
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    It's quite difficult to go wrong with the install but easy to make install mistakes for first timers. I don't think you'll have issues in the middle of no where. If it's running and you made all the necessary checks for clearance and your timing is correct. The install is no different than stock cams other than replacing upgraded springs. But that saying if it ain't broke...
    TodayWasTHeDaY, Torspd and Athlaos like this.
  15. Mar 6, 2023 at 7:06 AM
    #135
    Athlaos
    Leigh
    Edmonton
    Nah, they won't strand you - unless it's -40 out and you can't get it started. Ask me how I know....
    TodayWasTHeDaY and jamesepoop like this.
  16. Mar 6, 2023 at 8:07 AM
    #136
    nudavinci64
    Robert
    yah partially my thoughts.. How dod they so und installed? Dealing with Smog in CA is another issue and figured if it sounds cam'd prob not something easy to talk your way out of.
  17. Mar 6, 2023 at 9:05 AM
    #137
    jamesepoop
    California
    2007 Fj Cruiser
    IMO maybe maybe a car guy could tell but only on an aggressive cam profile. Otherwise, highly doubtful. Most smog techs probably couldn't tell. Heck they probably couldn't tell what your mods are other than it might not look stock. CA smog no longer does a sniffer/tailpipe test to my knowledge so as long as your monitors are checked and your visual on exhaust and emissions passes, you're good to go. Cams I would be less worried about as a non passing reason. At the age of our vehicles I'm more doubtful of the o2 and cats.
    Refer to Jessie's cam'd Taco or Torspd's vids on YT
    https://youtu.be/D4sa41PBmG4
    https://youtu.be/IGlyCOWXomY
    Torspd likes this.
  18. Mar 6, 2023 at 9:21 AM
    #138
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I remember that video. ^^^ :spy:
  19. Mar 6, 2023 at 10:37 AM
    #139
    nudavinci64
    Robert
    Nice I remember and forgot about that video. i was thinking of getting them in case I wanted to do it. I passed on 1st round then almost bought second hand then have passed on this one. but I keep coming back to it.
  20. Mar 6, 2023 at 2:19 PM
    #140
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    In CA, if a cop wants to be a dick and write you up for illegal mods, to the referee you go. And those dudes ARE car guys, WILL do a sniffer test, and WILL figure out it’s cammed, and then yank your registration. But that’s really a worst case and unlikely with a sleeper build Tacoma. They are after all the ricers in hopped up Civics and Subi’s
    jamesepoop[QUOTED] likes this.
