Kelford Cams GB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by modifyd!, Jan 16, 2023.
  1. Jan 16, 2023 at 6:31 PM
    modifyd!
    modifyd! [OP] Active Member
    going to cnc early next week per Kelford. Please dm me all your emails so I can send requests for the deposits. Only have three of your emails. As for shipping, right now I have paid for basically one consignment. Do you guys want to direct ship from Kelford or have me ship from NC, USA? I really don’t know which is cheaper. If you ship from Kelford there will be a freight difference to pay. If you ship from me, there will also be shipping so not sure which will be greater. Let me know your thoughts.
    not sure how to get deposits and such as I don’t want to come off 7k unless I absolutely have to. Not making a dime off this, just wanting to help the community. I have a 2021 loaded ram, a 69 boss 9, turbo 4Runner, 70 Mach 1 and a few others but in brutal honesty my 05 taco is my favorite. It was my pops and won’t go anywhere like the others if a good enough offer comes by. I don’t know what shipping costs will be, I assume it will be based on the weight once we determine exactly how many sets are floating over. Then we’ll need to figure once stateside to each of you. Never spearheaded a group buy, so if you have any suggestions, send them to me.
    prices: 3-5 sets 960, 5+sets 840 per set. I don’t have an idea for shipping yet.
    Edit: around $370 for springs. Shipping quote should be soon, talked to Kelford today.
    thanks
    Christopher
    @modifyd! 1GR 234-SC, springs
    @TodayWasTHeDaY 1GR 234-SC, springs
    @BassAckwards 1GR 234-T1, springs
    @miyashtaco 1GR 234-SC, springs
    @PhoS 1GR 234-SC, springs
    @rheath08 1GR 234-SC, springs
    @brian.gonz 1GR 234-SC, springs
    @chueflee 1GR 234-SC, springs
  2. Jan 16, 2023 at 10:14 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Torspd and 12TRDTacoma like this.
  3. Jan 17, 2023 at 6:50 AM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Somewhat interested depending on life circumstances and what kind of deal.
  4. Jan 17, 2023 at 10:44 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I bet that there would also be an interest from Aussie crowd. Since Kelford is in their backyard, and they have tons of 1GR owners.
    TodayWasTHeDaY likes this.
  5. Jan 17, 2023 at 11:23 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    You're running kelfords on your turbo 1GR right? I could be interested if this isnt limited to supercharged profile cams.
  6. Jan 17, 2023 at 7:08 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is correct. I would order a less aggressive profile though. As in less lift. As that requires clearancing the head for the lobes to rotate. Creates a big mess.
  7. Jan 18, 2023 at 6:11 AM
    modifyd!
    There may be the ability for the buy to maybe do two profiles. I can check with Kelford
    TodayWasTHeDaY and BassAckwards like this.
  8. Jan 18, 2023 at 7:13 AM
    BassAckwards
    Any idea what the most lift we could run without needing to clearance the head more?
    That would be great. Thank you
  9. Jan 18, 2023 at 9:30 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty much what the s/c profile is.
    Athlaos likes this.
  10. Jan 23, 2023 at 8:04 AM
    modifyd!
    Updates? The Kelford rep got back to me yesterday and can do a couple profiles. Just trying to get an accurate number of people before I just order mine. Figure we could all save shipping
  11. Jan 23, 2023 at 9:53 AM
    TodayWasTHeDaY
    Russ
    Calgary
    So I'm still half interested. I'm Canadian so I don't know if he'll waive full shipping, which is about $152 usd. That might be similar to you US peeps since Kelford is based in New Zealand.
    Would there be any discount on the parts at all, especially if springs are purchased as well?
    Athlaos likes this.
  12. Jan 23, 2023 at 10:22 AM
    Athlaos
    Athlaos Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    You need this mod. I can help you with it.
  13. Jan 23, 2023 at 10:38 AM
    TodayWasTHeDaY
    Russ
    Calgary
    And I'm 75% committed now hahaha
    Thanks for being a bad influence
    jamesepoop and Athlaos[QUOTED] like this.
  14. Jan 23, 2023 at 10:39 AM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I like my cams. Top end feels real good. Surprised many people.
  15. Jan 23, 2023 at 10:58 AM
    Athlaos
    Leigh
    Edmonton
    I'm an enabler.
  16. Jan 23, 2023 at 11:00 AM
    TodayWasTHeDaY
    Russ
    Calgary
    You buy those rims yet? :boink::D
    Athlaos[QUOTED] likes this.
  17. Jan 23, 2023 at 11:55 AM
    TodayWasTHeDaY
    Russ
    Calgary
    BillDaCat8, BassAckwards and Athlaos like this.
  18. Jan 23, 2023 at 11:58 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I saw this but unsure.I saw feedback that cams plus cam gears had less outplut.
    Anyone have any metrics on gains with the Cam? Been tracking @White lightning boosted truck that likley has been botched due to his Cam install (likely install error but none the less)
  19. Jan 23, 2023 at 11:58 AM
    Athlaos
    Leigh
    Edmonton
    I just sent him the money!!!
  20. Jan 23, 2023 at 12:00 PM
    Athlaos
    Leigh
    Edmonton
    I got good numbers with the cams installed. Have the retard gears on them as well. +50wtq on dyno after, decent high end too. Although I did replace headers, exhaust at the same time so there are other factors in there.
