KENTUCKY Buy/sell/trade/give
Discussion in 'Kentucky' started by Caboose117, May 6, 2017.
  1. Sep 25, 2018 at 6:25 AM
    #481
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    oops
  2. Sep 25, 2018 at 6:26 AM
    #482
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Then again.....sawzall, duct tape and zip ties....Make it fit
    dirty deeds[QUOTED] likes this.
  3. Sep 25, 2018 at 7:00 AM
    #483
    dirty deeds
    Nick
    Eastern KY
    I need to get my stuff gathered to clean out the garage a bit.
    :fingerscrossed: that someone wants a gently used 12-15 Super White front bumper cover w/ fogs. Includes crash bar, brackets, and hardware.
  4. Sep 25, 2018 at 8:33 AM
    #484
    DerbyCityTaco
    DerbyCityTaco The Air Cargo Guy
    Louisville Ky
    08 DCSB TRD OR
    Anyone got a line on some decent headlamp assemblies? Ive 'restored' mine a few times and they are still pretty rough. Was looking at Spyder, but the reviews are suspect and my search through the forums pretty much leads to "Get the Tacomabeast Spyders, because regular Spyders Suck". Anyone have them or can debunk the comments on them cracking, melting, sucking a year after purchase?
  5. Sep 25, 2018 at 9:08 AM
    #485
    dirty deeds
    Nick
    Eastern KY
    I think it boils down to people not using silicone to help seal them better, or just suck really bad at sealing them better when they use the silicone.
    My friend ended up getting some cheap $125/set black headlights and I ran a bead around the housing/lens. Been a few weeks and they're holding strong in this humid deluge of moisture we've had lately.
  6. Sep 25, 2018 at 9:21 AM
    #486
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Give them a year, the clear coat will start to peel.
  7. Sep 25, 2018 at 9:55 AM
    #487
    dirty deeds
    Nick
    Eastern KY
    I actually told him that we needed to do something on the lenses because of this. Also noticed they're quite flexible (thinner ABS) vs mine and his OEM lights.
    He barely drives it compared to his other Chevy work truck. He just went for looks and not longevity. Been like pulling teeth to keep him from buying a 3"+ spacer lift and get him to understand what will happen to his components putting that shit on there.
    MedlinAround[QUOTED] likes this.
  8. Sep 25, 2018 at 10:30 AM
    #488
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    How does this hurt any components?
  9. Sep 25, 2018 at 10:34 AM
    #489
    dirty deeds
    Nick
    Eastern KY
    C'mon, you know the answer man.
  10. Sep 25, 2018 at 10:48 AM
    #490
    presta24
    chris
    Cincinnati
    Actually I don't lol. Been running a spacer lift on my runner for at least 6yrs
  11. Sep 25, 2018 at 10:56 AM
    #491
    dirty deeds
    Nick
    Eastern KY
    From what I've gathered here, about Tacoma's, because I once thought I should get a spacer lift, is that it puts abnormal stress on things., when driven off road.
    Increased driveline angle, affecting the ring/pinion in the rear, carrier bearing, axle wrap potential, stretched or torn rear brake lines.
    Increased over stock angle in the upper BJ, causing them to wear out prematurely and fail.
    Increased angle of CVs, wearing out the front diff, hubs, torn boots, vibrations.
    Kept on mostly pavement, seems to be okay. But I can still imagine it's affected over time. Likely the same can be said about all our trucks that have full blown suspensions, too, but we drive them other places than the mall or granny's gravel driveway.
  12. Sep 25, 2018 at 10:59 AM
    #492
    presta24
    chris
    Cincinnati
    Almost all of that is affected with any lift....
    Bluegrass Taco likes this.
  13. Sep 25, 2018 at 11:36 AM
    #493
    Bluegrass Taco
    Bill
    Mt Washington Ky
    The ONLY thing "stressed" with a spacer lift that isnt effected by any other lift is the bottom end of front shocks. Shock travel runs out before suspension travel hits the limit. Shock becomes the bump stop. Rear blocks should be avoided if possible.... As Chris said, ANY lift changes drive line angles....tie rod angles...etc. 99% of claims regarding spacers are 100% bullshit.
    They arent the greatest but let's be real about the claims
    9 times in 10, spacers will be used with stock shocks. ANY shock that's worn or too light will give a less than stellar ride. And if you're spending the coin for newer/upgraded shocks, why not buy shocks/coils that give you the lift WITHOUT spacers? But the top plate spacer itself does nothing to negatively effect drive angles that a longer strut wont effect angles in the very same fashion.
    Plain Jane Taco likes this.
  14. Sep 25, 2018 at 2:26 PM
    #494
    DerbyCityTaco
    Louisville Ky
    08 DCSB TRD OR
    And that is my concern... Id rather polish the oems every 6 months if whatever replacements I chose would fade out in a year anyway and require the same leg work
  15. Sep 28, 2018 at 3:48 AM
    #495
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Not mine, but to a 50$ hard bed cover. Fits 1st gen short bed. Messaged him thinking it would fit mine :(
  16. Sep 28, 2018 at 5:43 AM
    #496
    dirty deeds
    Nick
    Eastern KY
    Love it when FB sellers are descriptive in what the item size/fitment is.
  17. Sep 28, 2018 at 6:01 AM
    #497
    beertimecontinuum
    Everett
    Yeah, I had to go through his FB pics to spec the Taco.
  18. Sep 28, 2018 at 6:02 AM
    #498
    dirty deeds
    Nick
    Eastern KY
    Stalker. I like it.
  19. Sep 28, 2018 at 6:03 AM
    #499
    beertimecontinuum
    Everett
    Lol, NOBODY has a Tacoma and doesn't post pics of taco to FB
  20. Oct 4, 2018 at 9:30 AM
    #500
    d.ben
    d.ben Member
    Dustin
    '17 Tacoma OR
    Hi, Looking to go a different direction so I'm selling my RTT and bed bars. The RTT was purchased directly from CVT in mid March 2018 and has been used 10-15 times. There are three completely cosmetic issues with the tent and it is otherwise in great working order.
    1. The underside of the floor is slightly dented from the ladder. (this is a known thing that happens)
    2. There is a very small tear in the flap that covers the gap between the fold out panels. This was due to me being careless once when I folded it up. It is not an 'elements protecting' part of the fabric and also doesn't protect against insects, just a flap that covers the seam. Hard to describe. See picture.
    3. The white lettering on the black cover has a few areas where it is flaking away. I haven't had any branches or otherwise abrasion on the top. Purely cosmetic and there are no tears.
    Tent comes with an additional non-stargazer awning and vestibule (never used). I have also upgraded quite a bit of the hardware to grade 8 bolts and good nylock nuts.
    The relentless fabrication bed bars were purchased around the same time. I used 'rattle can' bed liner to coat them multiple times and have touched them up in a couple places over the past few months. Mainly from when I put the RTT on/off once or twice.
    Looking for $1000 obo and am willing to meet within a relatively short distance from Cincinnati, OH - I am not interested in shipping. Check out the pics and let me know if you have questions.
    C2AB3886-014F-4122-99DF-85B01631FF07.jpg A0FC5C14-EADA-4C89-912E-39CF8EBF73FA.jpg 2AC5D26A-7BD1-4257-8916-AF73BFABC1A5.jpg
