kenwood dnx5120
Discussion in 'Audio & Video' started by chestnut35, Oct 6, 2009.
  1. Oct 6, 2009 at 3:51 PM
    chestnut35
    chestnut35 [OP] Well-Known Member
    tempe
    08 Off Road Double
    bixenon HID, chrome running boards, access tonneau cover, Bilstein 5100, rear TSB leafs, 18x9 XD wheels, 285/60/18 Nitto Terra Grapplers, Front Bull Bar
    Just wanted to see how hard the install is on this product. I was able to find one for about 300 and jumped on it and wanted to know how difficult it is or if i should just have someone install it for me
  2. Oct 6, 2009 at 4:46 PM
    stang88
    stang88 Well-Known Member
    its easy.
  3. Oct 8, 2009 at 9:47 PM
    dreamnz
    dreamnz Well-Known Member
    SoCal
    PreRunner
    Suspension: Camburg Spindles, Bilstein 5100s, Deaver Leafs, BFGs Audio: IDQ 10 in "Marv" box - Hybrid Audio L6 mid bass/ L4 mids / L1 ProSE tweets - RF Power / Arc Amps...BitOne.1 to control it all.
    I had the same thoughts with my 5120. I ended up installing it myself and got a lot of satisfaction from doing so and having saved on the ridiculous install costs I was quoted.
    Read through the install doc and post any questions you have.
    Hints..
    - Route the wire that's supposed to go to the parking brake to the ground.
    - Drill a small hole in the plastic that divides the inner dash from the vent area for the windshield defrosting vents and run the nav antenna wire through it. Mine's mounted dead center on the dash up near the windshield. I used high temp silicone to seal it in after I ran the wire so that no hot air would leak into the dash.
    - Reverse wire for a backup cam is easy to find in the wiring harness behind the drivers kick panel.
    - If you use a Scosche kit, you'll need to dremel/cut a notch out of the plastic mount so that the unit's exhaust fan will be unobstructed.
  4. Oct 30, 2009 at 7:00 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    Can you post the stereo color code?
    I have to install the DNX5120. Please help!!
  5. Oct 30, 2009 at 7:36 PM
    jmasterj
    jmasterj Samsonite...I was way off!
    07 TRD Off Road
