Kenwood DNX7140 USB Playback Issues
Discussion in 'Audio & Video' started by blacksandtaco, May 17, 2009.
  1. May 17, 2009 at 7:17 PM
    blacksandtaco
    blacksandtaco [OP] Well-Known Member
    Hey guys! I'm having issues with the MP3 files playing on my Kenwood DNX7140 via jump drive. There are certain files that the Kenwood skips over and will not play. The head unit recognizes the file but it won't play for some reason. I also noticed the head unit recognizes and lists files in the order in which they are added to the drive, rather than in alphabetical order which is very annoying when trying to search for files. Has anyone had similar issues?
  2. May 17, 2009 at 7:40 PM
    nermalgod
    nermalgod Well-Known Member
    Bend, OR
    Offroad boat hauler
    Not going to brag.
    Have you compared the files that won't play? Are they of a similar format, like AAC; something your computer can play but the Kenwood can't?
  3. May 18, 2009 at 8:16 AM
    blacksandtaco
    I've tried to compare the files but can't seem to distinguish any similarities/differences. I'm pretty sure they are the same format (MP3) and noticed that the file size is rather large. However, I have larger files that will play. I wonder if it has anything to do with the ID3 tagging?
  4. May 18, 2009 at 12:43 PM
    sooner07
    sooner07 1/2 man 1/2 amazing
    A A Ron
    DFW, Texas
    Debadged 2008 Rugged Trail
    Toytec ultimate lift kit, light racing UCAs, ARB bumper and full skid plates underneath. Looking into redoing the suspension and maybe repainting the ol' Taco.
    Could be that they are the older v1.1 tagging instead of v1.3 or how ever they are labeled these days.
    It may also be that they are variable bit rate files or even that they are in a bitrate higher than 256k or 320k.
    Try comparing them in a player like winamp and see what the bitrate is.
  5. May 18, 2009 at 12:51 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Have you updated the firmware you can down load it from kenwood website
  6. May 18, 2009 at 1:14 PM
    blacksandtaco
    I wasn't aware of any new firmware upgrades for this unit as it was just launched in March. I might need to check the bitrate because I imagine it is higher than normal.
  7. May 19, 2009 at 10:44 AM
    blacksandtaco
    I got some additional audio file specs that aren't listed in the owner's manual from www.kenwood.com/audiofile/ and it appears as though mp3 files need to be broadcast/produced in "Joint Stereo" for the head unit to play them correctly. Coincidentally, the two files that won't play are "Stereo" and "Mono". So, I'm not sure if this is the reason, but I can't help but think that it has something to do with it.
    I'm still not sure why the head unit recognizes files in "folder list" view as the order they were added to the drive and not alphabetically. Anyone else notice this on any of the DNX models?
  8. May 21, 2009 at 2:41 PM
    blacksandtaco
    Thanks for the advice everyone. I think I figured it out. Apparently the head unit doesn't recognize files like a normal computer would but rather it sorts files in the order they were added to the jump drive. I've read around some other forums that suggest using a software that will allow you to change the order in which a jump drive is read through the head unit. I will follow up on this if it works. Thanks!
  9. May 22, 2009 at 10:30 AM
    4x4Taco
    4x4Taco Well-Known Member
    Ontario
    07 TRD Off-Road 4X4
    Good luck...I actuallly like that "feature" as when I put together a MP3 drive for the Taco I control the order of titles just by how they are added to the drive. Once you are aware of it I think it works to your advantage.
  10. May 22, 2009 at 12:12 PM
    blacksandtaco
    Agreed, it can be useful for those who like to control their files that way. I like to be able to locate a file by genre and then artist so being able to list alphabetically gives me a quick search. Also, not all of my files are ID3 tagged properly, not the right genre or album name, etc. So I can only use the folder list option compared to the play list option. Currently when I want to add a new file here and there, I have to add all the original files plus the new ones at the same time in order for it to remain alphabetical and that is more time consuming than I'd like. I'm not sure if this will fix it but I'm hopeful that it will.
