Kenwood HU crashing/restarting on occasion…
Discussion in 'Audio & Video' started by dTed, Sep 17, 2021.
  1. Sep 17, 2021 at 12:43 PM
    dTed
    dTed [OP] Well-Known Member
    2013 DCLB SR5 4x4 MGM
    I bought a Kenwood DMX907S and installed it about 3 months ago or so.
    I’ve had a minor issue where the HU will crash and restart while I’m driving. I also have a Maestro, and the MPG gauges will also reset.
    Should I suspect the Maestro having an issue or the HU? It doesn’t seem to happen at any certain time, such as using a certain screen or hitting a bump in the road. Just happens randomly when I’m not even touching any buttons. Anyone else have this problem?
    My HU has the latest firmware update. This isn’t a major issue, mind you. It’s happened maybe 4-5 times over the past few months. I would just like to figure out the issue.
  2. Sep 21, 2021 at 4:00 AM
    jjglass535
    jjglass535 Well-Known Member
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    I have the same head unit. The first one I did the kenwood update before installing and had the same problem as you. Crutchfield sent me another one and I didn't update it and its been working good for close to a year. Not sure if that helps but something to think about. They sent me a new maestro first and that did not fix the problem. It was random in the middle of driving just reboot
  3. Sep 21, 2021 at 5:47 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    My pioneer does this pretty frequently and I’m pretty sure it’s the Maestro because right before it shuts off, the screen goes black and it throws the message
    “This function is currently not available” or something like that. And then it shuts off.
    I just haven’t taken the time to figure it out for sure.
  4. Sep 21, 2021 at 5:51 AM
    Clearwater Bill
    Billy
    Largo Florida
    Have you contacted the place you bought it from?
    Hopefully they can help
    dTed[OP] likes this.
  5. Sep 21, 2021 at 5:56 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    My OEM HU does this in my '14. Random, sometimes will go days without doing it and then this a.m. on my way to work it did it three times.
  6. Sep 21, 2021 at 5:57 AM
    Shellshock
    Iowa
    My dnx997xr does the same thing. It’s super inconsistent, it’s like it just crashes for some reason
    At first at thought it was the wiring but I pulled it out the dash and couldn’t get it to restart jiggling the wires. Eventually one day it did it while I was parked shortly after I started the truck.
    if it happened more frequently, I’d put more effort into trying to get it fixed
  7. Sep 21, 2021 at 6:11 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    My Kenwood does this from time to time. Sometimes it goes months, sometimes weeks. Its so infrequent I forget about it until it happens. Also have maestro, so this could be it. Never thought to check the gauges to see if anything changes there. Originally I thought it was the wiring, but not sure now. I have almost same headunit (same except one model year back) in my FJ with maestro and xm radio module and never had it crash once. idk..
  8. Sep 21, 2021 at 12:54 PM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    I still say it's kenwoods latest update.I didn't update my new head unit and it's been fine. Did it with 2 other kenwoods and 2 other maestros. Luckilly crutchfield just kept sending new stuff till I got it sorted out
  9. Sep 21, 2021 at 6:42 PM
    dTed
    Damn, thanks for the reply! Honestly this is what I wanted to hear. I contacted Kenwood and they suggested that I check all my wiring, and if that didn’t fix it to send it into a repair center.
    I was very careful to check every connection before installing, and I soldered the wiring, so I really don’t believe it’s that. I spent WAY too much time getting all the wiring shoved in so the radio and faceplate were flush, so I really don’t want to pull it out without having a solid suspicion.
    Did you happen to speak to Kenwood about your suspicions that it’s the update? I might mention it to them.
    I don’t seem to be getting any error messages of any kind, so I’m crossing my fingers that it is the firmware update like the commenter above. I’ll keep that in mind though!
  10. Sep 22, 2021 at 4:35 AM
    jjglass535
    Tampa, Fl
    2018 TRD Sport 4x4
    KDMAX Pro v.9
    Not sure if you can go backwards and remove the update but that was definitely my problem. I just figured the first time I would put the current update on before I closed it all up and it was an epic fail. Was doing the random reboot way too often. All good now
  11. Sep 23, 2021 at 4:19 AM
    dTed
    It’s not too much of a problem for now, so I’ll just wait until a new firmware update most likely haha. I think my main concern is if something is wrong with my specific head unit, but it’s so infrequent, I’m thinking it’s the firmware.
  12. Sep 29, 2021 at 5:42 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Yup that's the notification I get every time my pioneer shits the bed and turns itself off. I've thought about getting a different Maestro unit and replacing it but I dont have an extra $150
  13. Sep 29, 2021 at 6:04 PM
    destin_meeks
    Destin
    Tuscaloosa, AL
    That’s not the same error message it gives me. I’ve never seen this one before
  14. Oct 3, 2021 at 2:51 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Had this issue with the wifes 906s, now it restarts every so often instead of almost every time the vehicle is driving.
    I never bothered fixing it because its in her car...
    I believe I was told to try running the Accessory wire to the radio from before it goes into the Maestro.
    Something about it dropping accessory voltage out of the Maestro randomly causing the head unit to restart.
  15. Dec 18, 2021 at 10:04 PM
    Taco_Coma
    South NJ
    2018 DCSB SR5
    I did that with a jumper wire... it didn't help still restarts
  16. Dec 19, 2021 at 1:21 PM
    Purpleman
    Anaheim
    15 PreRunner
    Contact iDatalink aka Maestro and see what they say, their tech support is first class.
    Can also try reflashing the Maestro.
  17. Dec 19, 2021 at 1:25 PM
    Taco_Coma
    South NJ
    2018 DCSB SR5
    So what fixed it for you? the reflashing? feel like I flashed mine 3-4 times
  18. Dec 28, 2021 at 6:03 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
  19. Dec 29, 2021 at 8:03 PM
    Purpleman
    Anaheim
    15 PreRunner
    I didn't try anything....Its the headunit in my wifes car, so I just hear her complain about it.
    It used to do it almost every time she drove the car(2-3 times a week). Now it only does it about once a month.
    She has a DMX906s in her 2015 Corolla(which is basically the same headunit as yours).
    I have a 9906XR in my 2015 Taco and I don't think it has done it once to me in the last 10months.
  20. Jan 4, 2022 at 6:43 PM
    Taco_Coma
    South NJ
    2018 DCSB SR5
    I've finally fixed the problem. I contacted Auto Harness house (https://autoharnesshouse.com/11443.html) and used one of their wiring harnesses. The radio finally works like it's supposed to. I went with their steering wheel control module and ditched the Maestro; it ended up being 100 bucks for the module and all the harnesses I needed. So it cheaper than the maestro. It seemed like I would get a maestro error every-time it cut off. Put this harness in two weeks ago it hasnt turned off yet!... it was doing it like twice a week before... I probably just jinxed myself and it'll turn itself off tomorrow lol
