Kevlar my ass
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ob1-adobe, Dec 6, 2020.
  1. Dec 6, 2020 at 5:08 PM
    #41
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    Pull it, plug it, move on.
  2. Dec 6, 2020 at 5:09 PM
    #42
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    I do business with Dicount Tire but around here, last time I needed a repair for the same thing, a screw....uh yeah we can get to that in about 4-5 hours. I just put a plug in it myself. That plug held for the remaining life of the tire.
    Rockefelluh likes this.
  3. Dec 6, 2020 at 5:11 PM
    #43
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Better than getting your ass Kevlared.
    Hobbs likes this.
  4. Dec 6, 2020 at 5:22 PM
    #44
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    That was one of my Nevada adventures.
    No punctures or tears?? That is very difficult to believe the way you get after it! I would think that you eat tires on the regular.
    When I am due for new tires I'm gonna hit you up.
  5. Dec 6, 2020 at 5:38 PM
    #45
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    I break other things. My rear drive shaft is currently on it's way to Tom Woods. I had some really bad rotational vibrations coming back from Johnson Valley two weeks ago. I pulled the double cardon apart and it was way bad. The ball and socket had destroyed all but 7 of the needle bearings. The centering pin on the yoke side was mushroomed at the tip. The u-joints where in surprisingly good shape considering the cardon carnage. lol
    Hobbs[QUOTED] and tacotoe like this.
  6. Dec 6, 2020 at 5:47 PM
    #46
    zooyorkajd
    zooyorkajd Well-Known Member
    You’ll be back up and running
    44-16 Taco and shakerhood like this.
  7. Dec 6, 2020 at 5:50 PM
    #47
    TacoTaco24
    TacoTaco24 Wet behind the ears.
    Patrick
    Flowery Branch, GA
    2017 MGM DCSB
    Kevlar isn't stab proof. Just sounds good in marketing. :anonymous:
  8. Dec 6, 2020 at 5:59 PM
    #48
    UT_Runner
    UT_Runner Well-Known Member
    Taylor
    N. Utah
    19 Auto, DCSB OR, 6112/5160, stage 2 deavers, 255/80/17, Snugtop, Cement
    It's coming on to winter, grab a couple hundred more screws and stud that bitch.
  9. Dec 6, 2020 at 6:03 PM
    #49
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I would take it off and get it patched, that's what I do.
    Shelf Life and GSDLVR123 like this.
  10. Dec 6, 2020 at 6:07 PM
    #50
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    Get some e-ply tires, problem solved even if your back and hip pain gets worse.
    jetfishn likes this.
  11. Dec 6, 2020 at 6:09 PM
    #51
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    how many of those do i do to the tire?
  12. Dec 6, 2020 at 6:12 PM
    #52
    Hobbs
    Yep…
    Sounds like an inexpensive hobby!
  13. Dec 6, 2020 at 6:31 PM
    #53
    Anderson5290
    Anderson5290 Well-Known Member
    Brandon
    Corona, Ca
    2018 Tacoma TRD OR 4x4
    Tuned Fox 2.5 resi with dsc, JBA HD UCA, total chaos knuckle gussets, rear trd pro fox shocks, Deaver U402 stage 1 rear leafs, archive garage u bolt flip with fox 2.0 air bumps, White knuckle off road rock sliders, BAMF 1/4” steel skids, Magnaflow exhaust, Archive Garage Hammer Hangers, Cbi high clearance rear bumper, 285/75/16 tires.
    I’m petty sure it says right on the tire that the kevlar is in the tread and not in the sidewall. I haven’t had stock tires for over a year so not 100% sure.
  14. Dec 6, 2020 at 6:58 PM
    #54
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
  15. Dec 7, 2020 at 3:22 AM
    #55
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    User preferwnce if you like it
  16. Dec 7, 2020 at 5:56 AM
    #56
    Sungod
    Sungod Well-Known Member
    St Augustine
    Self admitted tire geek so apologize for the nerdiness, but need to set the story straight on Kevlar. Kevlar is not used for strength nor does it make your tires bullet proof. Goodyear has used aramid for years going back to the gatorback days. They switched to kevlar which is a brand name for aramid for obvious marketing reasons and unfortunately you get people that associate the product with bullet proof vests and think they have tires that are more puncture resistant. Kevlar is not used as a body ply, but used as a zero degree cap. It runs radial from bead to bead over the steel belting. The reason they use aramid/kevlar is that it shrinks when it heats. This keeps your contact patch flat as the tire spins. Pirelli uses a similar idea, but uses nylon because it is cheaper and has a higher shrink rate. The trade off is that nylon gets stiff when cold and you may feel a flat spot for the first few miles until they heat up. Sorry again, but it drives me crazy when incorrect information gets repeated. Now you know the rest of the story.
    Spare Parts, DocME, max_o and 10 others like this.
  17. Dec 7, 2020 at 6:06 AM
    #57
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    What’s the story with BFG G-Force Comp-2 A/S Plus? (asking for a Friend)
  18. Dec 7, 2020 at 6:36 AM
    #58
    Sungod
    St Augustine
    When I first saw that tire I thought "The aquatred is back!" BFG makes great track tires, but this is an all season which throws that out the window. For the price it is a good tire, but for a little more I would look at a Continental Pro Contact TX, Pirelli P Zero All season plus, or the Michelin Pilot Sport A/S. If they don't need A/S which 90% of those driving spots cars do not need, then look at the non all season Comp-2.
    The reason I say to look at non all season tires is that unless you plan on driving your car in snow or mud, you do not need an all season tire. Summer tires are designed for wet and dry and better in those conditions than a multi-purpose a/s tire. Everything in a tire is a compromise. To get the A/S rating you have to give something up and unless you plan on driving in those conditions you are giving something up like wet and dry traction for conditions that you will never operate in. Let's be honest, even if you get into those conditions an a/s tire isn't going to make a difference if you are taking your M3 to a mud bog.
  19. Dec 7, 2020 at 7:35 AM
    #59
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I could see those for sale at Wal-Mart. The “Huang-Dong Atlantis Eliminator” 117.22$ on rollback.
  20. Dec 7, 2020 at 7:39 AM
    #60
    ddanjeong
    ddanjeong Well-Known Member
    Dan
    19 OffRoad Double Cab
    265/75r16 General Grabber AT/X Diode Dynamics SS3 Sport Fogs / Ditch Lights UpTop Overland Bravo Roof Rack
    Swap out to some good e load tires. i havnt had a puncture with a e load so far (knock on wood).
    Anyone here have experience with a nail puncture in a e load tire? how did that go for you? did you plug it your self?
    Im running general grabber atx in a e load
