Kevlar my ass
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ob1-adobe, Dec 6, 2020.
  1. Dec 7, 2020 at 7:43 AM
    #61
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Plenty of times on construction sites. Shoot it full of fix a flat and then go to a tire shop and get it patched.
  2. Dec 7, 2020 at 7:49 AM
    #62
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I'm sure this was already covered but the Kevlar reinforcement is in the sidewall.
    Junkhead likes this.
  3. Dec 7, 2020 at 7:50 AM
    #63
    CalcityRenegade
    2023 T4R ORP KDSS
    I ran LT's for years without an issues. Got a smokin deal on a set of P rated tires and was constantly getting nails and screws in my tires. Back to LT for me!
    ddanjeong[QUOTED] likes this.
  4. Dec 7, 2020 at 8:23 AM
    #64
    Sungod
    Sungod Well-Known Member
    St Augustine
    A few layers of extra rubber can be the difference between a puncture and not. Other than that, Es really don't have anything more to ward off an object with a point than standard load tires. They patch just the same. The only difference is if you get a truck tire with a steel casing, you can then patch sidewall punctures. All steels ride like garbage on a light truck.
  5. Dec 7, 2020 at 8:24 AM
    #65
    Sungod
    St Augustine
    Uh, no. You are wrong. That is probably why you should have read this thread. Please read post #58.
    shakerhood and tcjacado like this.
  6. Dec 7, 2020 at 8:34 AM
    #66
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Thanks for the information. Apologies for the misinformation on my post earlier.
  7. Dec 7, 2020 at 8:52 AM
    #67
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I put six plugs in a single cut once. It got me back to civilization but a single plug will outlast the tire.
    Rockefelluh likes this.
  8. Dec 7, 2020 at 8:59 AM
    #68
    CalcityRenegade
    2023 T4R ORP KDSS
    I read post #58 which made no reference to Kevlar. Are you replying to the correct comment? If not I do not see where Kevlar is introduced other than the sidewall per the following excerpts from Goodyear.
    • Rugged strength provided by a layer of DuPont™ Kevlar®
    • Helps prevent cuts in the sidewall with its Durawall™ Technology
  9. Dec 7, 2020 at 9:16 AM
    #69
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    I agree, especially if it's a new tire. Although plug technology is better than it used to be, I still think the patch is a superior fix.
    CaptainBart45[QUOTED] likes this.
  10. Dec 7, 2020 at 9:23 AM
    #70
    Sungod
    St Augustine
    My mistake it was post 56. As I mentioned it is marketing. They are not marketing Kevlar as Durawall. You are drawing that conclusion which again is a marketing trap. Kevlar is DuPont brand of aramid which has been used for years. Does it provide strength? Yes so does nylon, ployester, rayon, steel, etc. That is the reason tires are not made simply of vulcanized natural rubber.
  11. Dec 7, 2020 at 9:26 AM
    #71
    Ob1-adobe
    Ob1-adobe [OP] Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    actually it was not free and not under warranty. cost $25
  12. Dec 7, 2020 at 9:28 AM
    #72
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Ive never paid for flat repairs at my tire shop. Discount is charging you?
    GreyBaldTaco likes this.
  13. Dec 7, 2020 at 9:30 AM
    #73
    Ob1-adobe
    No I actually decided to go to the dealership. I thought it was covered under the Toyota care, but apparently not. In retrospect I wished I went to discount tire. probably would have been faster.
  14. Dec 7, 2020 at 9:35 AM
    #74
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Spend less than $10 on a nice T handle plug kit. It is worth it to just not wait for a puncture repair or hear some story about how the puncture us just outside the allowable area or tread wear.
    https://www.amazon.com/Slime-1034-T-Handle-Tire-Plug/dp/B000ET525K
  15. Dec 7, 2020 at 10:04 AM
    #75
    Sungod
    St Augustine
    The official word is that the old gas station plug is a temporary fix. I can see the rationale because it doesn't create an adhesive bond that patching from the inside does nor does it allow you to see the inside of the tire that could be destroyed from running low on air. I have seen tires that looked normal on the outside, but when you dismounted it that the inner liner is literally a pile of dust inside the tire. Of course if it is your tire, you know how you treat it and if you found a screw in the tread and it was still holding air when you pulled it out and quickly put a plug in that you are as good as new.
    The concern with the plug is that there is nothing to hold it in place. You push it in and it is held in place by force. I understand the theory, but I can tell you that I have never heard of one backing out. I am sure it could happen, but I would imagine that you can probably attribute it to installation error.
  16. Dec 7, 2020 at 10:23 AM
    #76
    CalcityRenegade
    2023 T4R ORP KDSS
    Gotta love marketing wank eh?
  17. Dec 7, 2020 at 11:32 AM
    #77
    Sungod
    St Augustine
    Goodyear is one of the best. They spend double on advertising per tire than their closest competitor. Michelin is one of the lowest. They focus on quality. Price wise there are usually close and it always shocks me that people buy them just because of things like Kevlar.
  18. Dec 7, 2020 at 11:33 AM
    #78
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    You joke but ive done that and its stopped the leak, temporarily at least :rofl:
    BalutTaco[QUOTED] likes this.
  19. Dec 7, 2020 at 11:38 AM
    #79
    Ob1-adobe
    The shit thing is I didn't notice I had a screw in my tire for almost 24 hours. By the time I found out the tire was practically flat.
  20. Dec 7, 2020 at 11:40 AM
    #80
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    You have to use at least 3 kits.
