Key comes out of ignition when turned on -- 2nd gen
Discussion in 'Technical Chat' started by BenWA, Aug 16, 2012.
  1. Aug 16, 2012 at 4:05 PM
    BenWA
    BenWA [OP] Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    My key has been falling out of the ignition while driving lately. I guess the bits that lock the key into the keyhole are not functioning. I don't know much about keys/ignition assemblies, but is this a simple fix? Such as some kind of lube or something? Or would I need to have the whole shebang replaced?
  2. Aug 17, 2012 at 8:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Do you have more than one key? Try a different key first. I had one older Toyota that did that, but only with the wore out key that I used every day. The spare was fine. I've seen it on an old Chevelle too.
  3. Aug 17, 2012 at 9:00 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I had a truck that did that ... I love that feature in the winter for warming up the truck and locking the doors.
