key comes out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yahta07, Dec 14, 2020.
  1. Dec 14, 2020 at 6:51 AM
    Yahta07
    Yahta07 [OP] Well-known
    2007 tacoma
    6 inch lift 33s fuel maverick rims 12 inch sub woofer set spyder headlights aftermarket grill
    After I start my truck my key comes out easily and truck stays running and drives off. Any solutions?
    six5crèéd likes this.
  2. Dec 14, 2020 at 6:54 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Welcome to the forum.
    New ignition is it. All the older Toyota's had this problem.
    DG92071 and LoveableWerewolf like this.
  3. Dec 14, 2020 at 7:00 AM
    reg0928
    reg0928 Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    My 05 key comes out too. I like it cause I can start my truck to warm it up then take my keys and unlock/lock my camper shell to load up ski gear while the truck warms up
    LarryDangerfield and Yahta07[OP] like this.
  4. Dec 14, 2020 at 7:01 AM
    YotaProject
    YotaProject Well-Known Member
    Adrian
    Charleston SC
    Fox Lifted 2007 Taco With Mods Here & There
    Mine does the same thing, the key has worn down enough that there's no hard edge to keep it in the ignition anymore.
    Yahta07[OP] likes this.
  5. Dec 14, 2020 at 7:09 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    As long as it always comes back, I don't see a problem.
    :rimshot:
    JdoubleU and coopcooper like this.
  6. Dec 14, 2020 at 7:09 AM
    Muddinfun
    Muddinfun Well-Known Member
    Although it’s possible that the ignition lock cylinder has some wear on it, the most likely cause is a worn out key. Look at the key. If it’s obviously worn thinner and the notches are all rounded looking, you need a new key. If you have a blinking red car symbol light on the dash when the key is out, you need an immobilizer key. That gets a little bit involved. If you come back to this thread, we’ll point you in the direction you need to go.
    Continuing to use a worn key is really bad for the lock cylinder. It forces the wafers to go when they’re not perfectly aligned, causing wear to the wafers and the lock cylinder.
  7. Dec 14, 2020 at 7:30 AM
    Yahta07
    2007 tacoma
    Just for fun my buddy tried to start my truck with his hyundai key and the truck would crank but not turn over
  8. Dec 14, 2020 at 7:36 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    i used to be able to start my dads truck my truck and my buddies truck with the same key,
    anyways. probably a worn ignition
  9. Dec 14, 2020 at 8:19 AM
    Muddinfun
    That tells us 3 things.
    1. The lock cylinder is worn out.
    2. Your truck needs an immobilizer key.
    3. You’re not aware that crank and turn over mean exactly the same thing.
