Key doesn't turn?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sig Taco, Mar 30, 2021.
  1. Mar 30, 2021 at 6:33 AM
    Sig Taco
    Sig Taco [OP] Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    I think this 3-4 times now since I got my SR5 in November. Push the key in and it doesn't turn. I have to fiddle with the keys for maybe 30 seconds before it turns.
    Any ideas on why?
  2. Mar 30, 2021 at 6:38 AM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    Is the steering wheel turned all the way left or right when this happens? Sometimes when the steering wheel is at full lock, it binds the ignition switch. You actually have to pull the wheel a little farther in the direction that it is already turned, to take the pressure of the key switch. It happens in my OR occasionally also. I used to see this a lot in older GM vehicles. I was a bit surprised the first time I experienced it in a modern Toyota.
  3. Mar 30, 2021 at 6:39 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I have a push to start but I'd imagine you're sitting on the steering wheel lock making the key hard to turn. Try moving the wheel a little bit and see if the key turns like normal.
    zoo truck and NoVa TRD Sport like this.
  4. Mar 30, 2021 at 6:40 AM
    Swartzy165
    Swartzy165 Well-Known Member
    Nashville, TN
    2023 CM Tundra // 2020 MGM ORP T4R
    I took off an air dam once
    definitely sounds like the steering wheel lock is engaged
    bubba swift and Taco_Coma like this.
  5. Mar 30, 2021 at 6:48 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Sounds like the steering wheel lock is engaged. Turn the wheel a little and it should work.
    RedWings44 likes this.
  6. Mar 30, 2021 at 7:51 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Joining the bandwagon, wiggle the steering wheel and turn the key, I sometimes engage the steering lock with my knee when I get out.
  7. Mar 30, 2021 at 7:53 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Do you guys think it might be the steering lock?
  8. Mar 30, 2021 at 7:57 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    No, I think it's the steering wheel lock. Probably should jiggle the steering wheel. Little known fact.
    SR-71A, RedWings44 and Jojee117 like this.
  9. Mar 30, 2021 at 7:58 AM
    Swartzy165
    Nashville, TN
    is it friday already? :bananadead:
    shakerhood and CttAznRanger like this.
  10. Mar 30, 2021 at 8:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    Agreed.
    They have caused consumer aggravation since 1968.
    shakerhood likes this.
  11. Mar 30, 2021 at 8:07 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Manitoba
    3G, Tuned
    Steering wheel lock? Need to know.
    @Sig Taco ?
  12. Mar 30, 2021 at 8:18 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I guess l will go out on a ledge and say Steering Wheel Lock...
  13. Mar 30, 2021 at 8:31 AM
    tclavell
    Troy
    Phoenix, AZ
    G70
    it may or may not have been mentioned but have you checked steering wheel lock?
    kas2828 and shakerhood like this.
  14. Mar 30, 2021 at 3:36 PM
    wiljayhi
    Jim
    Manitoba
    3G, Tuned
    It’s funny how some request assistance from TW members, but never acknowledge that any suggested action has resolved the problem.
  15. Mar 30, 2021 at 3:38 PM
    KBOX
    KBOX In a va.. *cough* truck down by the river.
    Jody
    Acton, Ontario
    2017 Tacoma DC Sport V6M 4X4
    Stock
    IMHO, the steering wheel lock, should be checked.
  16. Mar 30, 2021 at 3:50 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Check into the steering lock if none of the other solutions have worked.
    tclavell likes this.
  17. Mar 30, 2021 at 3:58 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    What kind of oil are you running and how often do you change it??
  18. Mar 30, 2021 at 4:04 PM
    RedWings44
    Michigan
    Should've gotten the skewp
  19. Mar 30, 2021 at 4:09 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Sounds like driver error to me
  20. Mar 30, 2021 at 6:19 PM
    MaverickT883
    Maverick
    Ontario, Canada
    Check build thread!
    Truck is totaled. Part out. How much for the wheels?
