Key don’t work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BuildbyBarz, Sep 24, 2019.
  1. Sep 24, 2019 at 3:44 PM
    BuildbyBarz
    BuildbyBarz [OP] Well-Known Member
    Johnny
    SrQ 941
    14 MGM DCSB
    Friends don’t let friends drive stock
    hello I was trying out my keys today and the one on the right don’t work when I try to crank up I thought it was a dead battery and than I try the left key and it turn the truck on. any idea ? Maybe because it a spare key? Sorry for newbie question
  2. Sep 24, 2019 at 3:46 PM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Is it programmed ?????????
    IIRC......only so many keys can be programmed to one truck ........
    Kolter45 and verynearlypure like this.
  3. Sep 24, 2019 at 3:50 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Looks like a generic copy. I recently lost the valet key to my 4Runner. Instead of spending $115 to replace it, I had a $5 copy made at Home Depot. It'll unlock the doors, but won't start the engine. Good for when I go to the beach and I only need a key to unlock the truck and don't care if it gets wet.
  4. Sep 24, 2019 at 4:03 PM
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    That pretty smart I am going to start doing that
  5. Sep 24, 2019 at 4:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The key on the right doesn’t look to be the type to have a transponder chip within it.
    It will likely only open the doors. Maybe the glovebox as well.
    It’s been a long time but, I think my grey key wound not unlock the glovebox?
    I know there was something about the black key that the grey would not do.
  6. Sep 24, 2019 at 4:19 PM
    replica9000
    2019 T4R ORP
    Grey key is valet key. Both my 4Runner and Tacoma came with one. It was pointless for the Tacoma as I didn't have a locking glovebox.
  7. Sep 24, 2019 at 4:26 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Then key on the right does not have a chip in it.
  8. Sep 24, 2019 at 4:33 PM
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    Thanks guy for the help I was losing my mind.
  9. Sep 24, 2019 at 4:58 PM
    smartbomb
    smartbomb rcvr/xmtr
    usually northwest of you
    2006 4-door prerunner long bed
    3" suspension lift, hard canopy, light bar in hood, ditch lights, aircraft cargo bars, powdercoated steel spares, desert tires, bed cargo bars (for rifle cases), misc interior doo-dads
    I have the exact opposite problem. I only have one key, and it just starts the engine. I have to use the key fob to get in
    that's right folks, the key that starts the truck won't open it
  10. Sep 24, 2019 at 7:12 PM
    Boostntsi
    Boostntsi Well-Known Member
    Las Vegas, NV
    2013 Tacoma Double cab 4x4
    Icon suspension all around and some other stuff
    Same here :annoyed:
  11. Sep 24, 2019 at 10:20 PM
    Muddinfun
    Muddinfun Well-Known Member
    Oil the door lock. My locksmith recommends Triflow.
    Kyitty likes this.
  12. Sep 25, 2019 at 1:15 PM
    nphueber
    nphueber Member
    Syracuse, NY
    2006 Tacoma TRD Off Road
    I recently found out I have the same problem, how did I find out might you ask? My battery "died"(corroded contacts) and my doors were locked...
    The solution? Hooked up a spare battery to the positive terminal on the starter, grounded to the frame and it was enough juice to pop the locks. I also threw some Dri-Slide into the locks, it didn't work right away but seems to have freed things up by now.
  13. Oct 3, 2019 at 3:39 PM
    smartbomb
    smartbomb rcvr/xmtr
    I tried it. I even used Triflow as you commented. it didn't work.
    But thank you for the suggestion anyway
  14. Oct 3, 2019 at 4:17 PM
    Muddinfun
    OK, from there, the fix is still very easy. Open the door. On the edge of the door is a round black plastic plug. Pop it out. Then you will see a torx head bolt. Turn the bolt about 8 turns. There's a plastic clip that prevents the bolt from falling inside the door. Then just pull the lock out and take it to a locksmith and tell them to fix it so your key works.
    Note: When the lock is out, the door handle comes out very easy. It goes back in just as easy. Just so you know.
    TnShooter likes this.
  15. Oct 3, 2019 at 6:49 PM
    TnShooter
    Deogee
    STOCK
  16. Oct 4, 2019 at 7:31 AM
    Michaelo
    Michaelo Well-Known Member
    Michael
    PNW
    2014 Regular Cab 4x4 5 Speed
    I have the opposite problem to the OP. I have a copied key that opens the doors and starts the engine but my OEM Toyota pair are hit and miss....
  17. Oct 4, 2019 at 7:33 AM
    Muddinfun
    Hit and miss? Wanna be a little more specific?
  18. Oct 4, 2019 at 7:43 AM
    Michaelo
    Michael
    PNW
    They sometimes require jiggling of the keys and moving the steering wheel to start the truck. The copy has never had an issue. I think something is wearing in the ignition cylinder and the copy has lower tolerance than oem ones. :notsure:
  19. Oct 4, 2019 at 7:51 AM
    Muddinfun
    Either the OEM keys or the locks are worn. The person that cut the copys is either a genius and compensated for the wear or they got lucky making an inaccurate copy. Take the truck to a locksmith and ask them what's going on. A good locksmith can look at a key and tell exactly what the problem is.
    Michaelo likes this.
