Key fob help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by WVtaco888, Dec 5, 2018.
  1. Dec 5, 2018 at 11:52 AM
    WVtaco888
    WVtaco888 [OP] New Member
    2017 inferno Toyota Tacoma sport
    Working on it
    Anyone know where to get an aftermarket key fob with buttons?
    I gave my roommate my keys to get in my truck and he left them on my bed cover. By the time we found them they were run over. The metal key saved the electronic components but the plastic case is destroyed. All the aftermarket cases look like they don’t come with buttons. Any help would be greatly appreciated.
  2. Dec 15, 2018 at 2:07 PM
    Bugmanbrian
    Bugmanbrian Well-Known Member
    Brian
    2018 sport
    I have a 2016 key fob for tacoma Limited $50.00
  3. Dec 15, 2018 at 9:00 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Try auto parts store. They have the cases and you just have to use the insides. It's just covers, factory copies. Auto zone sells them.
  4. Dec 15, 2018 at 9:02 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to TW!
  5. Dec 16, 2018 at 3:12 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    I have a few for sale, you can get them cut at your hardware store
    https://www.tacomaworld.com/threads/new-key-fob-hyq12bdp-oem-3-button.581846/
  6. Dec 16, 2018 at 9:15 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    You should be hitting the roommate up to replace it with OEM.
    DRansom likes this.
  7. Dec 27, 2018 at 7:09 PM
    WVtaco888
    Working on it
    Just checked on this. We found an OEM case or so we thought. Said fits Tacoma and Prius... well it almost did but I wanted to keep the rubber seal in there and wouldn’t fit with that. So he ordered the AJT case and the factory lock and emergency buttons fir perfect (the unlock button was lost somewhere when we found all the pieces in the dark) then I used the unlock button that came with the OEM case and had to shave it down a little bit because it was slightly bigger than stock. Everything works fine. The unlock button is a little janky but I use keyless entry anyway. I’m gonna go by my local dealership and see if they have any broken ones laying around with buttons(now that I’m in WV instead of Cali). He offered to buy me an entirely new keyfob from Tacoma at first but wanted a cheaper option and I was okay with it because all the component worked fine. Wish I would have seen @Bugmanbrian post before he ordered. Would have saved a lot of frustration but all’s well that ends well.
  8. Dec 27, 2018 at 7:14 PM
    Oscar I
    Oscar I No longer a toyota driver
    They lumped in some key protection with my tire protection BS when I bought my truck. You might be able to get one if they had an extra warranty of any kind.
    WVtaco888[OP] likes this.
  9. Dec 27, 2018 at 7:51 PM
    WVtaco888
    Working on it
    Good to know
