Key Fob Keyless Entry Remote
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eddiekc, Aug 1, 2020.
  1. Aug 1, 2020 at 2:55 AM
    Eddiekc
    Eddiekc [OP] Active Member
    If I buy the keyless entry remote online for my 2007 Tacoma would it have the instructions to program it or do I have to take it to a shop?
  2. Aug 1, 2020 at 3:05 AM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Pretty sure you'd need a Toyota dealer to program it but you could call a locksmith first to see if they can do it which I'm sure would be cheaper.
  3. Aug 1, 2020 at 3:06 AM
    Eddiekc
    Okay, will do. Thanks for the reply.
    Fatback17 likes this.
  4. Aug 1, 2020 at 7:35 AM
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Had mine done by lock smith just needed to bring the original with it
  5. Aug 1, 2020 at 8:30 AM
    TheBigKahuna
    TheBigKahuna Well-Known Member
    EdgemanVA likes this.
  6. Aug 1, 2020 at 8:47 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Was going to suggest looking at YouTube before visiting a dealer or locksmith.
  7. Aug 1, 2020 at 9:10 AM
    Eddiekc
    TheBigKahuna,
    Thanks for the video. Once I get it, going to try it. :thumbsup:
  8. Aug 1, 2020 at 9:16 AM
    Jacked Burton
    Jacked Burton Well-Known Member
    35s 4.30s 6speed TruTrac Fx Pros Bilstiens Dakars
    Tires: 35/11.5/17 Toyo AT3s Wheels: FN FX Pro Gunmetal 17s with TRD center caps Zinc Metallic lettering. Yukon 4.30 gears with TruTrac Front Suspension: OME 887 w/5100s, Freedom Offroad UCAs n Superbumps Rear: Archive Hammer Hangers,Dakar Mediums, Bilstien 5125s Ubolt flip n Superbumps, Headlights: Selfmade Retrofits URD shortshift kit Airaid CAI No name throttle controller
    Depends on the key model.
    The dot chips you can do yourself.
    There is a different one that has to be done by a locksmith/dealer.
  9. Aug 1, 2020 at 9:18 AM
    Eddiekc
    How can I tell if mines is a dot chip?
  10. Aug 1, 2020 at 9:19 AM
    Muddinfun
    Muddinfun Well-Known Member
    Dot has to do with the immobilizer key. NOT the fob.
    FOB Programming:
    There are four different programming commands when setting up or verifying your remote transmitter, they are:
    1. Add mode, used to add a remote to your car that is not currently registered.
    2. Rewrite mode, used to erase all previously registered remotes and allow you to begin again theprogramming process.
    3. Confirmation mode, used to verify the number of remotes that are already programmed in your car.
    4. Prohibit mode, to prohibit allremotes from operating the door locks.
    https://www.carandtruckremotes.com/...eplacement-keyless-entry-control-remotes.html
    Procedure To Program ToyotaWireless Remote Transmitters:
    Begin with: The driver's door open and unlocked. Key out of the ignition.
    1. Insert and remove the key from the ignition switch 2 times within 5 seconds.
    NOTE: Steps 2 and 3 should beperformed within 40 seconds.
    2. Close and open driver's door TWICE.
    3. Insert the key into the ignition andremove it.
    NOTE: Steps 4 - 6 should be performed within 40 seconds.
    4. Close and open the driver's door twice.
    5. Insert the key into the ignition.
    6. Close the door.
    NOTE: Steps 5 and 6 should be reversed for the following models ONLY (closedoor first, then insert key into ignition):
    2000 - 2005 Celica
    2001 - 2003 Prius
    2001 - 2005 ECHO
    2001 - 2005 RAV4
    2003 - 2004 Avalon
    7. Turn the ignition switch from"Lock" to "On" and back to "Lock" at about 1 second intervals to select the desired mode:
    1 time for ADD mode.
    2 times for REWRITE mode.
    3 times for CONFIRMATION mode.
    5 times for PROHIBITION mode.
    8. Remove the key from the ignition.
    9. To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a number of times corresponding to your key cycles in step 7.
    NOTE: If Confirmation or Prohibition modes have been selected, opening the door will complete the procedure.
    10. For Add or Rewrite modes do the following within 40 seconds of Door
    Procedure Lock confirmation:
    A. Press both car transmitter Lock and Unlock buttons simultaneously between 1 and 1.5 seconds and release.
    B. Within 3 seconds of step A, press the transmitter Lock button for more than 1 second and release.
    If the keyless entry remote transmitter has been successfullyprogrammed, the power locks will cycle "lock" to "unlock" once at this time.
    If there are problems with the remote transmitter or the procedure up to this point, the locks will cycle twice. If thisoccurs, verify that you have received the correct transmitter, and then repeat the above procedure.
    C. If multiple remotes are to bereprogrammed, repeat steps A and B.
    11. Open the driver's door to conclude programming mode.
