Key fob programming mode cycles 11 registered fobs to system after reset?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverBullet08, Nov 30, 2022.
  1. Nov 30, 2022 at 11:40 PM
    SilverBullet08
    SilverBullet08 [OP] New Member
    2023 Tacoma TRD
    Hey folks!! I am brand new to the board with a question that has been a thorn in my side for about 8 years. Having to do with the key fob programming of my 2nd gen ‘08.
    In the latter functions of the jump-up/turn-around 3 times/blink twice/close eyes/fart/open eyes/close eyes… turning key in the ignition 5 times to erase all existing remotes, 3 times to check how many key fobs are then registered, resulting in the locks cycling 11 times. Shouldn’t that number be 0 hence I just did the ‘all delete’ or is that somehow a glich?
    Maybe a pre-installed default number(though seemingly high) from the factory? Any ideas or reasoning?
  2. Nov 30, 2022 at 11:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    My data shows this.
    So 11x looks to be the correct number:thumbsup:
    1. In Confirmation Mode, if no recognition codes have been registered, LOCK-UNLOCK operation will occur 11 times.
    reallifedog and Jimmyh like this.
  3. Nov 30, 2022 at 11:52 PM
    SilverBullet08
    2023 Tacoma TRD
    Awesome!! Amazingly quick!! Thank you!!
    though forgive me if this sounds elementary,
    cycling 11 times refers to 11 fob entries available or 11 fobs programmed? Sorry, it’s late.
  4. Dec 1, 2022 at 12:11 AM
    TnShooter
    Deogee
    STOCK
    It means there are NO fobs currently programmed.
    The maximum is 4. After 4 the next one will delete the 1st one.
    1. Add Mode is used to register new recognition codes while retaining the previously registered codes. This mode is used when new transmitters are added. If the number of registered codes exceeds 4, the previously registered codes will be erased in order, starting from the first registered code.
    Jimmyh likes this.
  5. Dec 1, 2022 at 12:53 PM
    SilverBullet08
    2023 Tacoma TRD
    Well explained!! Thank you!!
    Jimmyh and TnShooter like this.
