Key fob remote start stopped working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dhauck, Jan 11, 2024.
  1. Nov 12, 2024 at 11:06 AM
    TacoTimePNW
    TacoTimePNW Member
    Did you ever figure this out? Mine abruptly stopped working on Monday (11/11/24). On Sunday, I remote started the vehicle with the fob, then never ended up entering the vehicle (presuming the remote start automatically shuts off the vehicle after a set amount of time). I have never installed the Toyota app. Remote start has always worked until now. Now it will not remote start with the Fob at all. Click, click, click+hold. I do not get the multiple flashes indicating that remote start is initiating.
  2. Nov 12, 2024 at 11:20 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    start w the basics- does your fob work at all? Does it lock/unlock the truck?
    Try the functions from the other fob. Check the fob’s battery.
    RIX TUX likes this.
  3. Nov 12, 2024 at 11:36 AM
    TacoTimePNW
    TacoTimePNW Member
    start w the basics- does your fob work at all? Yes
    Does it lock/unlock the truck? Yes
    Try the functions from the other fob. I have one fob
    Check the fob’s battery (relatively new battery)
    My instinct tells me it has something to do with not opening the door when activating remote start on Sunday. Usually, I remote start every morning, then enter and restart, then drive off.
    Never had an issue until now.
  4. Nov 12, 2024 at 11:43 AM
    TacoTimePNW
    TacoTimePNW Member
    "I do not get the multiple flashes indicating that remote start is initiating."
    To be clear, when typically clicking the fob, each time it will blink once, then after holding on the third click for roughly 3 seconds, it will blink about 6-8 times to signal that remote start is starting. The clicks all flash properly, just not the 6-8 times after holding on the 3rd click. Hopefully that is clear.
  5. Nov 12, 2024 at 2:35 PM
    MindlessCorpse
    MindlessCorpse Well-Known Member
    2020 Tacoma TRD sport
    Yep, mine stopped working recently as well, lock--lock--lock and hold.
    It did work when I bought the truck Jan 18th 2024.
    It is kind of a pisser. One of the features advertised but has disabled itself.
    Along with the advertised leather-not leather seats, and the Limited Slip Differential, not Limited slip Differential.
    2020 TRD sport.
    girMobi likes this.
  6. Nov 12, 2024 at 3:35 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Mine has always worked on the fob with lock, lock, lock/hold for at least 10 seconds.
    Sometimes have to try a few times and be within 20 yds of truck.
    Never got multiple flashes to confirm.
    Never used the app.
  7. Nov 12, 2024 at 3:39 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what kind of car would help
  8. Nov 12, 2024 at 3:41 PM
    RIX TUX
    it cost money to have it
    BillF1564 and Ngneer like this.
  9. Nov 12, 2024 at 4:16 PM
    Ngneer
    Ngneer Well-Known Member
    Done this as well, put “new” battery in it, no go. Carried to a local locksmith, 1st question, battery. Yep, not good a new battery. Mayb we could get a battery mfg. here in our country now so just ordered a new lock/unlock fob, alls good.
  10. Nov 12, 2024 at 8:29 PM
    MindlessCorpse
  11. Nov 12, 2024 at 9:31 PM
    RIX TUX
  12. Nov 13, 2024 at 5:21 AM
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    Add mine to the list of recently stopped working. I never installed or used the APP, just the fob and it's no longer working.
  13. Nov 13, 2024 at 8:17 AM
    MindlessCorpse
    @RIX TUX can you repeat the obvious 5 more times? it's so informative.
  14. Nov 13, 2024 at 10:13 AM
    RIX TUX
    it might be because it was free for 3 years and now you have to pay for it
    edit: free for one year i think but some people it keeps working but then stops one day for unknown reason, might be related to the model
    BillF1564 and drizzoh like this.
  15. Nov 13, 2024 at 10:26 AM
    #35
    RIX TUX
    cost either way.......buying connected services or aftermarket electronics
    i never used it, just get in and drive
    petethemeat and BillF1564 like this.
  16. Nov 13, 2024 at 10:50 AM
    #36
    Chew
    Chewy
    Midwest
    19 TRD OR
    ugh, it sounds like maybe it's more of a software problem than a hardware problem
    BillF1564 and TacoTimePNW like this.
  17. Nov 13, 2024 at 10:53 AM
    #37
    TacoTimePNW
    TacoTimePNW Member
    @RIX TUX - Not sure what you're trying to add to the conversation. We're trying to figure out a seemingly easy problem. Remote start is already installed and has functioned for 4 years now, just recently stopped working. Other people are having the same problem. No need to spend money, this is likely a software issue. Actual input is appreciated.
    @crashnrondo - Did anything change recently? What year Taco? Do you have Connected Services or only use the Fob?
    Does anyone know a Toyota tech we can tag here for input?
  18. Nov 13, 2024 at 10:53 AM
    #38
    TacoTimePNW
    TacoTimePNW Member
    Exactly...I'm not looking to spend the $12 per month or whatever for the app. The fob has been working just fine for my needs.
    crashnrondo likes this.
  19. Nov 13, 2024 at 11:38 AM
    #39
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    Have you seen the documentation or remember where it was posted about the 1 or 3 years for the key fob? I sorta remember something with the 2020's stopping after a year but Toyota got a bunch of grief and did something to let the key fob continue to work and I thought there was no time frame. I can't find it now of course but I know I read it on here.
  20. Nov 13, 2024 at 11:45 AM
    #40
    Chew
    Chewy
    Midwest
    19 TRD OR
    I don’t blame ya! If it’s tech you paid for, that they’re trying to force you to pay for.
    My new F150 work truck has remote start from the app only at no extra charge.
    RIX TUX and crashnrondo like this.
