Key fob remote start stopped working
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dhauck, Jan 11, 2024.
  1. Nov 13, 2024 at 11:58 AM
    #41
    crashnrondo
    crashnrondo Well-Known Member
    Ron
    Wisconsin
    2021 DCSB Limited
    @crashnrondo - Did anything change recently? What year Taco? Do you have Connected Services or only use the Fob?
    Never used connected services, only the fob. Nothing changes other than my USB input stopped working.
  2. Nov 13, 2024 at 12:00 PM
    #42
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    IIRC, in another thread regarding the same thing I think one of the possibilities was that if the vehicle had a code that effected the vehicle in some way the FOB Remote Start was disabled until the code(s) were cleared. A safety issue.
    Certainly not all codes as I currently have an Air Bag deactivated and I temporarily unplugged the 4x4 module and in both cases the vehicle started using the FOB.
    Added: The OP can ignore this as his inquiry was in January.
  3. Nov 13, 2024 at 12:05 PM
    #43
    TacoTimePNW
    TacoTimePNW Member
    That's great insight, I'll check that tonight. No CEL is currenly on in the dash.
    Toycoma2021[QUOTED] likes this.
  4. Nov 13, 2024 at 12:06 PM
    #44
    TacoTimePNW
    TacoTimePNW Member
    That's odd, do you use the USB for something other than charging?
  5. Nov 13, 2024 at 12:16 PM
    #45
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    Nope not a thing. I did use it to update the firm ware trying to fix it and I was able to do that but it didn't fix my problem. I really don't think the two things are related. I don't have any errors or codes so that's not the starting problem either, I'm guessing the 3 year thing is probably right but it pisses me off. How long before they turn off the heated seats or sunroof?
    MindlessCorpse likes this.
  6. Nov 13, 2024 at 12:53 PM
    #46
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    no documents i found but my sticker says one year and some here have said it worked after a year, i have the connected services for 80 a year and never use the remote start...... you just have to try and see if it still works if you "need, cant live without" remote start
    BillF1564 likes this.
  7. Nov 13, 2024 at 12:56 PM
    #47
    RIX TUX
    its a fluke if it still works for free after a year.....its free for 1 (one) year
  8. Nov 13, 2024 at 12:58 PM
    #48
    RIX TUX
    a money problem
  9. Nov 13, 2024 at 1:02 PM
    #49
    TacoTimePNW
    TacoTimePNW Member
    I'm not exactly sure what the "3 year" stipulation is, but I do recall at purchase that Connected Services was included for 1 year. People here have said that FOB remote start stops when Connected Services is terminated. In both of our scenarios, it doesn't seem to make sense since neither of us have had Connected Services initiated.
    crashnrondo[QUOTED] likes this.
  10. Nov 13, 2024 at 1:26 PM
    #50
    TacoTimePNW
    TacoTimePNW Member
    My understanding is that "Connected Services" are free for a year. Fob is running on some internal hardware, likely unrelated to the app.
    crashnrondo likes this.
  11. Nov 13, 2024 at 1:26 PM
    #51
    TacoTimePNW
    TacoTimePNW Member
    If Toyota truly turned this off remotely, that sounds like a greed problem, not a money problem.
    Tacoma1845, Barsoom and crashnrondo like this.
  12. Nov 13, 2024 at 1:40 PM
    #52
    RIX TUX
    i guess it cost money to make it work, it seem to work from a cell or satellite signal
  13. Nov 13, 2024 at 1:41 PM
    #53
    RIX TUX
    you can do the remote start without the app
    Barsoom likes this.
  14. Nov 13, 2024 at 1:46 PM
    #54
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    I just talked to Toyota, she told me there is no time limit on the key fob starting the truck, only the app that is free for one year. Another guy at work also has a 2021, and his still works with the fob, he did it in front of me in the parking lot. The lady from Toyota said I'll need to go to the dealer to have it diagnosed.
    Barsoom likes this.
  15. Nov 13, 2024 at 3:06 PM
    #55
    Toycoma2021
    Are you using a professional scanner that scans all systems? The off-the-shelf cheap scanners may not see it.
    Are all your doors latched? Normally, how have you been locking the vehicle during the last period where the FOB was successful in Remote Starting. Are you sure it is locked prior to trying the FOB to lock and Start the vehicle?
    Added: What I am trying to get at is that the truck may not think it is locked because a latch detector may be not working properly. Has it recently gotten cold where you are?
    Try the FOB remote start while looking at the display over the steering wheel.
  16. Nov 13, 2024 at 3:52 PM
    #56
    TacoTimePNW
    TacoTimePNW Member
    Which Toyota phone number did you contact? Local dealership?
  17. Nov 13, 2024 at 4:06 PM
    #57
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    No scanners used, I don't have a CEL or any warning on the display. If something was serious enough to stop remote start wouldn't I have something come up without needing a professional scanner?
    When it has worked in the past the truck was in several different conditions, locked with the door button, locked with the fob, and unlocked. All worked.
    I opened and closed all doors several times, locked the truck, and checked all the doors without a key nearby. Then I waited a few minutes and tried the remote start again while my wife watched the display. Nothing came up there while doing it except for the blinker flashes coinciding with the button presses.
  18. Nov 13, 2024 at 4:07 PM
    #58
    crashnrondo
    Ron
    Wisconsin
    2021 DCSB Limited
    Just the customer service national 1-800 number, not a dealer.
    TacoTimePNW[QUOTED] likes this.
  19. Nov 13, 2024 at 4:09 PM
    #59
    TacoTimePNW
    TacoTimePNW Member
    I did the exact same thing, same results. Has worked perfectly since December 2020, no issues - ever. I'll try disconnecting and reconnecting the battery and report back.
  20. Nov 13, 2024 at 4:40 PM
    #60
    Toycoma2021
    Codes can still be present with no indications to us users.
    I'll give two examples:
    A personal example was when I went to have my windshield replaced and the TSS camera realigned. Before starting the job, it was the technician's practice to check for any outstanding codes as a TSS alignment would not be allowed with any stored codes. He said I had 23 codes; I had no CEL or any other indications, he was able to clear them, if not I was off to the dealer as no glass work could be done.
    I have Techstream and every time I use it there are lots of codes present - none have lit the CEL. I also do a lot of work on my vehicle with missing modules all the time, so my codes are expected and meaningless, but they do not permanently light a CEL. Or they expire and the CEL goes out, but the code is still in the system.
    Sounds like a good thing to do.
    I've tried to find the instructions in the Owner's Manuel as to the instructions and "conditions" on using the FOB to remote start and have not been able to. Find those conditions and read them paying attention to each as if they are a caveat. It was something so simple that led to the solution in a previous thread. My searching abilities on this site are pathetic.
