Key fob trouble on 2016 tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sandtaco13, Oct 9, 2018.
  1. Oct 9, 2018 at 9:36 PM
    Sandtaco13
    Sandtaco13 [OP] Member
    Quicksand 2016 tacoma 4x4 sport
    hey tacomaworld!
    I currently have a 2016 taco 4x4 sport and i noticed a few months ago my key fob has lost its signal distance whatsoever. I have to be at arms length from the door and sometimes i have to click the fob more than once for it to open. Also, if i want to open the door without the key fob while its in my pocket it doesnt work either. I have to take the fob out and hold it next to the door for the signal to pass through. I already replaced the batteries twice on both key fobs and still no luck. I wonder if it could possibly be that the person that installed my audio didnt do it correctly or when they installed my push buttons in the cubby. Maybe they connected it to the wrong cable and its acting up. Im screwed cus my milage went over the warranty and the dealership will probably charge me a fortune. Has this happened to anyone?
  2. Oct 9, 2018 at 9:52 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    That really sucks. The audio install is the variable but that stuff shouldn’t be powered when the ignition is off. Unfortunately those guys use some very crappy splicing techniques sometimes. The fob is passive with the proximity system. The equipment to check the carrier signal from the truck is an oscilloscope and a sensor that converts its frequency to voltage.
    If I were you I’d take it to the audio shop and show them it barely works then ask them to unhook their power splice and see if it returns to normal.
  3. Oct 10, 2018 at 6:11 AM
    Sandtaco13
    Ill do that because it gets tedious having an inoperable fob
  4. Oct 10, 2018 at 6:48 AM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Did they, or did you, install a dash cam?
    Installing a rear dash cam can sometimes cause interference that can negatively impact the range of your key fob signal, depending upon how the wiring is run through the headliner.
  5. Oct 10, 2018 at 8:50 AM
    Sandtaco13
    No, i dont have a dash cam but it could probably be the audio that they connected on my truck thats causing the problem
