Key issue or ignition cylinder issue?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GiggityBurns, Sep 21, 2022.
  1. Sep 21, 2022 at 6:57 AM
    GiggityBurns
    GiggityBurns [OP] Member
    2009 Tacoma 4x4 TRD OR
    So I’ve come across a weird issue. My second key belongs to my wife and from the moment she first used it, it was difficult to turn. We had to manipulate the angles to get it to turn.
    I noticed the last few times the truck would be on the accessory position after she’d be done driving. She swears up and down that she double checked it was off before she got out. Turns out the key comes in and out easily with the key in the acc position and she said she accidentally knocked it out earlier when she went to retest.
    My key does not have any issue like that, so would this be a key issue or an ignition cylinder issue? With that being said, does anyone know the cost of a key/ the programming or the cost of an ignition cylinder?
  2. Sep 21, 2022 at 9:23 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds more like a lock cylinder problem, are both keys OEM?
  3. Sep 22, 2022 at 8:12 AM
    GiggityBurns
    I’m not sure, I bought the truck with both sets. I did notice the problematic key is thinner and not as long, but it doesn’t look aftermarket. I’m moving more towards the key being suspect
  4. Sep 22, 2022 at 8:32 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Maybe get a simple key cut for a couple bucks and try it, it won't start the truck because of the immobilizer but will at least tell you if it's the key or the lock cylinder.
  5. Sep 22, 2022 at 9:40 AM
    Waasheem
    Waasheem
    2007 xrunner
    It does sound like a key problem. MAYBE a regular chipless key will work with the chip key near the ignition switch?
    Dm93 likes this.
  6. Sep 22, 2022 at 10:07 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You could do that as well, as long as the transponder key is within an inch or so of the lock cylinder it should read it.
