Key locked in truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ceslee01, Oct 26, 2022.
  1. Oct 26, 2022 at 4:03 AM
    Ceslee01
    Ceslee01 [OP] Member
    Cesar
    2012 toyota Tacoma
    I have 2012 toyota tacoma prerunner
    I locked my keys in the truck, I have a sliding window but there no button or handle to open is there a way to take it off
  2. Oct 26, 2022 at 4:05 AM
    TomYotaNH
    TomYotaNH Well-Known Member
    Tom
    Seacoast NH
    '16 Barcelona Red DoubleCab Limited
    Almost Stock - BedRug, Power Tailgate Lock, ….
    AAA
    TexasWhiteIce likes this.
  3. Oct 26, 2022 at 4:08 AM
    Mater96
    Mater96 Well-Known Member
    AZ
    2019 Tacoma Offroad 4x4
    Amber DRL retrofit Fox 2.0 coilovers and reservoir shocks
    I remember doing the same thing back in highschool with my Nissan. Thankfully i left the back sliding window always unlatched out of the fear of doing that. But yeah AAA or a locksmith is your easiest bet.
  4. Oct 26, 2022 at 4:13 AM
    Ceslee01
    Cesar
    2012 toyota Tacoma
    Not near one in the mountain working
  5. Oct 26, 2022 at 4:15 AM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Check out those videos of people putting duct tape on the window then pulling on the duct downward to force the window down. Looks easy.
  6. Oct 26, 2022 at 4:19 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    That rear sliding window can be easily opened with a Leatherman, flat head screwdriver, etc. Just take your time.
    This assumes you're able to fit through the window.
    Then stash a spare key somewhere on your truck.
    AJKlug1 and armartin like this.
  7. Oct 26, 2022 at 4:31 AM
    armartin
    armartin Member
    SoCal
    06 DCSB PreRunner
    After doing this once I now stash a key. I had a key cut but not programmed, so itll unlock the door but if someone finds it they can’t run off with the truck.
  8. Oct 26, 2022 at 5:16 AM
    Ceslee01
    Cesar
    2012 toyota Tacoma
    I have one of those slim Jim but can’t really use it to good been trying to find the lock
  9. Oct 26, 2022 at 5:20 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I've opened a bunch with a metal coat hanger slipped between the door and top of the cab.
    Dm93 likes this.
  10. Oct 26, 2022 at 5:26 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Yeah, thats not a thing. At least not without breaking things.
    Lots and lots of videos online are just for views, and not actually "life hacks"
    steelcity2[QUOTED] likes this.
  11. Oct 26, 2022 at 5:31 AM
    steelcity2
    Pittsburgh Pa
    Oh. Never tried it. Plus don't want to break things.
  12. Oct 26, 2022 at 5:36 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Worst case, smash the rear passenger side or rear drivers side door. Those are the cheapest to replace. Like $75.
  13. Oct 26, 2022 at 5:53 AM
    XSplicer62
    XSplicer62 Well-Known Member
    Jefferson State
    2005 Tacoma DC TRD OffRoad
    Yep.... whatever you do, don't damage your rear slider. Unless things have changed, that's only sold as a complete assembly. VERY expensive.
    TexasWhiteIce[QUOTED] likes this.
  14. Oct 26, 2022 at 5:55 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    At work we use a plastic wedge in the top corner of the door and slip a plastic coated rod in to hit the door lock button when keys inadvertently get locked in something, works 90% of the time.
  15. Oct 26, 2022 at 6:13 AM
    Waasheem
    Waasheem
    2007 xrunner
    I watched aaa do it. Used an inflatable bladder to force a gap open between the top of the door and cab. Then used a long coat hanger like thing.
    It doesn’t matter where you are. Call aaa, they come to you. You might have to pay a fee for being far away.
    Taco-Obsessed and SR-71A like this.
  16. Oct 26, 2022 at 6:28 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Good luck. Get a credit card key for next time... won't start the truck but it will get you back in. I've had to use mine a couple times. :facepalm:
  17. Oct 27, 2022 at 2:47 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I've locked my keys in my truck twice since 2008 when I got it. The rear slider is easy to open with a wire bendable enough to slide in between the weather striping on the clip side and strong enough lift the clip. Can be done fairly fast, scary fast. Did it both times at work and was able to get wire from the maintenance shop.
  18. Oct 27, 2022 at 3:01 PM
    bagster
    bagster Well-Known Member
    I carry my spare key minus flob in my wallet.
  19. Oct 27, 2022 at 6:35 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    Hate to even broadcast it, but this forum has been so helpful to me - only do this when you absolutely need to, and don't be an asshole - you can slide the manual rear window open with enough gumption without breaking the glass, and slide through enough to hit the unlock button.
  20. Oct 27, 2022 at 6:43 PM
    devkurf
    devkurf Member at Large
    midwest
    This is what I did. it stays in the glovebox in the side of the bed. I just used it again yesterday.
    armartin likes this.
