Key Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rossdlover, Feb 16, 2013.
  1. Feb 16, 2013 at 5:24 PM
    rossdlover
    rossdlover [OP] New Member
    Ross
    Ocean Springs, MS
    05 Tacoma
    18" toyota wheels
    I have noticed that every once in a while I have problems turning the ignition key, but the other day I took a sharp left turn and the key fell out.... Guessing the lock cylinder is going bad??? Anyone else had this problem and how do you resolve it so the ignition key is still the same as the door key???
  2. Feb 16, 2013 at 7:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have the dealer install a new ignition switch matching the cylinder pins to the door locks. They may be able to just replace the cylinder, not sure.
  3. Feb 17, 2013 at 4:53 AM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    New cylinder for sure. Never had a key come out when the car is running.
  4. Feb 17, 2013 at 5:32 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I was able to pull one of my keys out of my last truck while it was in the on position. It was the key itself, the spare key I rarely used would stay in. Do you have a spare key to compare it against?
  5. Feb 17, 2013 at 5:35 AM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    This first
