Key Problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ron in Indy, Jan 8, 2020.
  1. Jan 8, 2020 at 3:20 PM
    Ron in Indy
    Ron in Indy [OP] Member
    Ron
    I had an interesting problem with our 2013 Tacoma which we purchased a couple months ago, and I'm wondering if anyone else has seen this. When I got the truck, it only had one key and one remote fob. I had the dealer make two new keys from the original and another fob. I drove it home using the original key, but after I tried the new keys (both worked) the original key stopped working. It fits normally in the starter, and doesn't appear to be worn, but it simply will not turn anymore, no matter how much I try wiggling and tweaking it. As I said, the other two keys are fine, but I'm wondering what happened to the original. Any thoughts?
    Cheers,
    Ron in Indy
  2. Jan 8, 2020 at 6:39 PM
    RyanTacoMC
    RyanTacoMC 96 Tacoma LX (RIP)
    Bay Area, CA
    2005 Base Access Cab 5-Lug RWD Manual
    4x4 Springs, QA1 TS703s, Rear Sway Bar, blah blah
    Be happy, you have two keys that work! My used car came with three keys and they're all iffy! But, try shooting in some graphite powder and see if that helps. Otherwise... professional explanation:
    Ron in Indy[OP] likes this.
  3. Jan 8, 2020 at 9:58 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Originally key probably worn down some, ignition cylinder pins may have gummed up/wore out little bit to kind of match the key. When you used a new fresh key it pushed the cylinder pins all the way to the correct position and now that they move more the old worn down key doesn't push them far enough to clear the lock.
    Hard to describe if you don't know how the internal lock cylinder is set up.
    Best bet would be to squeeze some dry graphite power into the lock and turn it back and forth to lubricate the internals.
    Most any auto part stores should have little tubes of the dry graphite power you can buy.
    Ron in Indy[OP] and DG92071 like this.
  4. Jan 8, 2020 at 10:08 PM
    DG92071
    DG92071 Well-Known Member
    Exactly.
  5. Jan 9, 2020 at 4:32 AM
    Ron in Indy
    Ron
    Thanks for the ideas. I was trying to come up with a logical explanation (other than Gremlins :) )
    DG92071 likes this.
  6. Jan 9, 2020 at 12:10 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    This exact situation stranded me in a mall parking lot. There was a Toyota dealer who cut me a new chipless key from the VIN. Still didn't work... Turn the key and hit the end of the key, bingo! Thanks YouTube... Also found a vid on removing the ignition cylinder.
    Took that with the key code from the dealer to a locksmith. Rebuilt for 35 bucks. I used a screwdriver to start the truck , while holding the fob next to that ring that was around the ignition cylinder.
    What a fun little vacation side adventure.
  7. Jan 9, 2020 at 3:43 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Did dealer change the ignition switch....does orig key still work the door lock?.
  8. Jan 9, 2020 at 4:47 PM
    Ron in Indy
    Ron
    Same ignition switch. I actually drove it home from the dealer with the original key. I also checked the drivers side door, and the old key and new keys work.
