key stuck in acc position
Discussion in '1st Gen. Tacomas (1995-2004)' started by penguinflies, Dec 11, 2011.
  1. Dec 11, 2011 at 10:06 PM
    penguinflies
    penguinflies [OP] Member
    Saint Louis, MO
    '96 Tacoma
    Been searching for the best answer but seems to happen to more floor shifters than column shifters.
    I have a 1996 Tacoma and when I put it in park, I can turn off the ignition and move the key to acc. Key will not go to off and I cannot pull it out of the ignition cylinder.
    I disconnect the battery and the key can move to the off position and is released for extraction.
    I read in some forums that is could be slop in the shifter, the ignition solenoid, or the ignition cylinder.
    Is the ignition solenoid the same/integrated in the ignition cylinder?
    --thanks
  2. Dec 11, 2011 at 10:08 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Try this: Put shifter into N. Try to turn it off. Put shifter into P.
  3. Dec 11, 2011 at 10:15 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    This happens to me sometimes, usually when I forget to take it out of gear, but give it a half turn clock wise then back and it should release. On my Dad's Boxster this is a big problem with the plastic peices at the end of the locking mech(Not sure what it's called) breaking and not being able to retrieve the key so maybe replace that?
    Also try babytruck's idea she's pretty smart.
  4. Dec 11, 2011 at 10:32 PM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    thanks for the tips, but neither work. The key can go from inserted off, acc, on start. When either in park or neutral and truck running, key can go from position on to acc, but not off. Only way I can get the key to off is to disconnect the battery.
  5. Dec 11, 2011 at 10:35 PM
    babytruck
    NorCal
    Have you tried to push the key in deeper into the keyhole as you are turning?
  6. Dec 12, 2011 at 8:16 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    I just tried it again in the daylight, no bueno
    I connected the battery, pushed the key in the "lock" position, and turned over the truck. It started and the shift indicator says park. I then put the shifter in neutral and turned off the truck, and placed the shifter in park. Pushing/jiggling the key gets me to the ACC position and almost to lock, but not all the way there.
    Btw, I dont need to press the brake anymore to put the truck in gear. Seems like the shift isn't all the way in its locked position. I am going to take off the steering column plastic to see if maybe the shifter is not hitting it's sensor to say, hey stupid, i'm in park.
  7. Dec 12, 2011 at 8:26 AM
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    sometimes you need to turn the wheel to the left or right .. not sure why this locks the key in the ignition, but it does
    edit: NVM .. this is when you are starting the car .. my bad
  8. Dec 12, 2011 at 8:28 AM
    babytruck
    NorCal
    My next question was going to be: "Do you have your foot on the brake?" :p
  9. Dec 12, 2011 at 8:42 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    took apart the plastic covers and found the bolt holding the shifter to be loose, I took it out and it is damaged. The shifter is held in place between two metal brackets on column, secured by a 10 mm bolt that should go through the assy.
  10. Dec 12, 2011 at 8:44 AM
    YoaterBoater
    YoaterBoater Well-Known Member
    Mississippi
    2002 PreRunner DblCab
    Running tubes, Toolbox
    I had the same thing happen to me. I wiggled it forever and finally got it to the off position. Once you get it out, change keys. That ended up being my problem somehow. Good luck
  11. Dec 12, 2011 at 8:45 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    I know right, seems 90% of the problems are usually solved by operator error. Will take a pic of the bolt and it's location if this solves the problem.
    Right now the 1996 tacoma is at 199427, I need 575 more miles to 200K and dammnit, I'm going to make it.
  12. Dec 12, 2011 at 8:48 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    No, you are correct, I can start easy, it's turning off that is the problem. With my current problem, the steering wheel will not 'lock' when turning left or right.
  13. Dec 12, 2011 at 8:53 AM
    babytruck
    NorCal
    Glad that you found the problem. Keep us posted, I want to know that it got fixed. :)
  14. Dec 12, 2011 at 10:29 AM
    DNG
    DNG Well-Known Member
    Orange County, CA
    White 01 DC PreRunner
    Sometimes my key gets stuck in acc when I'm not completely shifted in P. It'll be engaged in P, but the shifter requires another small click upwards to be able to unlock the key
  15. Dec 12, 2011 at 11:59 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    Yes, I suspect it is more the column shifter not reaching it's home in Park. Bolt was $1.86 and is located in KC. Toyota says they'll have it in St. Louis by noon tomorrow.
  16. Dec 13, 2011 at 10:51 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    Picked up the part, installed and I will make it to 200k! Bolt was the problem. There was also a missing 10mm nut that secured the bolt into position, I had a spare nut to install. Tightened shifter in bracket to stop the wiggle/play and the key will turn to lock flawlessly now.
  17. Dec 13, 2011 at 10:53 AM
    penguinflies
    Saint Louis, MO
    '96 Tacoma
    steering wheel now locks when turned, brake pedal must be pressed to get out of park, and truck operates as intended.
    Randykendallsr likes this.
  18. Dec 13, 2011 at 10:55 AM
    babytruck
    NorCal
    Wow that's great! And thanks for sharing the pics, people are definitely going to learn from this! :)
  19. Dec 30, 2016 at 6:27 PM
    Haleycook37
    Haleycook37 New Member
    2000 Toyota Tacoma PreRunner
    My truck was having this same problem I have a 2000 Toyota Tacoma PreRunner and my shifter is in the floor. My truck wouldn't turn off and would get stuck in the acc mode and I would have to unhook the battery to be able to take the key out. I thought it was somethin with it not registering that it was in park, or somethin with the ignition switch but figured out the actual problem was something with electrical because when the battery was unhooked it would turn fine but hooked it wouldn't so I started trying to play with stuff and there is a little white box with two screws right under the ignition switch and all I did was loosen those two screws and now it works perfectly fine and comes out everytime.
  20. Dec 31, 2016 at 12:29 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Wow, that bolt had seen some torque from time to time it looks like. Looked like it was a lil used up!
