Key Stuck in Ignition
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adams0213, Aug 6, 2017.
  1. Aug 6, 2017 at 7:54 PM
    Adams0213
    Adams0213 [OP] New Member
    Hunter
    1998 Regular Cab Toyota Tacoma
    So i have a 1998, 5 Speed Toyota Tacoma. I can put the key in the ignition and start my truck and turn it to the ACC and everything fine but i can't get the key to come out of the ignition. Any thoughts on how to fix this?
  2. Aug 6, 2017 at 8:05 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Your ignition cylinder tumbler is worn out and needs to be replaced. I believe you need to get access to the sides of the cylinder to push in a little tab that will allow the whole thing to slide out.
    cruxofthebisquit likes this.
  3. Aug 6, 2017 at 11:11 PM
    Rburdeaux
    Rburdeaux Well-Known Member
    2004 Double Cab Prerunner
  4. Aug 7, 2017 at 12:06 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    No, use a silicone spray instead. WD40 is good for rusted bolts not for lubrication. After some time WD40 turns into sticky goo making things worse for longer run.
    In places like locks silicone spray is great. While fresh sprayed it flushes dirt and old oil, when dries it leaves a residue that is non sticky and repels watter.
  5. Aug 7, 2017 at 3:09 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    This happens to me when I use my wal-mart cut spare key. Is your steering wheel locked too? When I accidentally lock the steering wheel it also locks the key in the ignition. What you can do is jiggle the steering wheel or push it to one side simultaneously when trying to turn the key and the ignition tumbler will unlock.
  6. Aug 7, 2017 at 6:29 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  7. Aug 7, 2017 at 6:37 AM
    NM Lance
    NM Lance Well-Known Member
    I frequently had this issue in the winter. My lock mechanism was very sensitive to the steering wheel position even though the ignition switch was in the "off" position.
    I am sure you have already tried, but in case you haven't...you may try rocking the wheel lightly against its stops as you wiggle the key.
    Get a new ignition switch. They are relatively easy to replace yourself, but keep in mind you will have a different key for the door and ignition unless you are somehow able to get one keyed alike. I went with a non-OEM replacement and it has worked very well since installation.
    Dalandser likes this.
  8. Aug 7, 2017 at 8:52 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Happened to my 98. You can take your ignition apart and remove some tumblers in there. If you are in an area prone to high crime don't do that. Worked for mine. Cheap fix.
  9. Aug 7, 2017 at 9:02 AM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    Have you been using a Toyota key or a HD/Walmart replacement? The cheap replacement keys are prone to getting stuck like this.
  10. Aug 7, 2017 at 9:06 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Use this on any and all locks.....
  11. Oct 15, 2018 at 4:31 PM
    Mogger1
    Mogger1 New Member
  12. Oct 15, 2018 at 4:33 PM
    Mogger1
    Mogger1 New Member
    If your truck is an automatic the issue is in the shift lock release cable attached to your ignition lock
  13. Oct 15, 2018 at 4:35 PM
    Mogger1
    Mogger1 New Member
    Do not use graphite in your locks. It is worse than you can imagine if you do.
  14. Oct 15, 2018 at 4:37 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    I just replaced the ignition on my 2000 4runner, fairly cheap replacement, maybe $60. The down side I now have 2 keys. You have to be able to move to the acc position to get the old one out. Replace the ignition switch now before it’s too late.
