Key that open doors but doesn't start a truck.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by egres, Feb 8, 2014.
  1. Feb 8, 2014 at 8:06 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Only got one once... that was a Ford in 1991. I've purchased 3 Toyotas, 1 Chevy, and 3 Fords "New in box", plus company cars.
  2. Feb 8, 2014 at 8:09 PM
    InSight Retrofits
    InSight Retrofits Closed
    :eek:
  3. Feb 8, 2014 at 8:17 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    My keys are "L" as well.
    No chip.
  4. Feb 8, 2014 at 8:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    If your dealership doesn't do the plastic credit card key check out AAA .
  5. Feb 8, 2014 at 8:43 PM
    dionysis
    dionysis G.A.S. (Gear Acquisition Syndrome) sufferer
    Jim
    Northern Colorado
    08 DCSB SWB Auto V6 Stock, for now
    In my manual of my 2008 sport there is a plastic valet key. Haven't used it but I just saw it there the other day.
  6. Feb 10, 2014 at 5:45 PM
    egres
    egres [OP] Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    Do me a favor, look at your key. One side of the blade is mirror image of other. Meaning both sides look the same. It make sense, because it does not matter how you put your key in the lock it will turn. So only one side of the blade is working at a time.
  7. Feb 10, 2014 at 6:44 PM
    bvlpxm
    bvlpxm Well-Known Member
    pat
    Upstate South Carolina near Spartanburg but have l
    2014 DCSB TRDsport 4x4
    AVS vent shields & bug deflector - Floor Mats - AVS sill protectors- Gentex K51a auto dim,temp, compass, homelink - OEM Bedmat - Pulled TRD Sport decals-frame undercoat - DU hitch cover- Gloss black high temp paint Brake Drums, Calipers, Muffler back exhaust - OEM Bedmat - CK Neosupreme Seat covers
    you say your key is non chipped & you want a type of immobilizer function? Well back in day we did something like this that you may want to consider : Tap into the start circuit out of the ignition switch or anywhere along the harness. Spit the wire & run it as a switched circuit to a hidden toggle switch. Flip the switch to open & no key will start it.
    the other scenarios like folks mentioned if u just want a door key & do have a chipped key you can get a non chip key made most anywhere for a couple bucks. I like to do this for my "hide a key " & keep a chipped key stashed inside the truck. Also like to take a simple non chip key when I'm doing stuff where I am apt to lose a key or drown one & simply lock my good key & remote in the truck.
  8. Feb 10, 2014 at 6:53 PM
    egres
    DELCO PA
    Good point, a kill switch is on my to do list this summer. Unfortunately, I do not have a chip. So i was hoping on making a "door key" somehow. I did a small experiment, I shaved off one side of the blade of the key and it opens doors and start the truck. But you can only insert a key one way now. Second I cut off 1/8 from the tip and it made it hard to insert and would not open door or start the truck.
    Could you look at your key and see if one side of the key blade is mirror image of other blade? Thank you.
  9. Feb 10, 2014 at 11:04 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes. They are mirrored sides.
  10. Feb 11, 2014 at 5:49 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well probably if you have nothing to hide it would save you a lot of grief to just let them search it. Guess you have never been through US customs with your vehicle.
  11. Feb 11, 2014 at 8:17 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If they have " Real Probable Cause " they will search it regardless if the door is locked or not. How do you spell Baton. Or they can just detain you long enough for a search warrant.
    Focus on Not Giving Them probable cause.
  12. Feb 12, 2014 at 8:05 AM
    egres
    DELCO PA
    I think it's personal opinion at this point. I could give you probably dozens of scenarios why it's bad idea to let LEO to search anything.
    I had some negative encounters and some positive like nice chit chat about handguns when was pulled over for clearing intersection after red light. LEO was not sure if I did cut the red light or not, he just asked and I told him that due to traffic I was not able to clear intersection before red light. He saw my handgun in my car holster and we chatted about guns. I had xds9 that just came with recall and he was considering buying one. He never asked for my permit because he had no reason to.
    So anyways. that was positive encounter. And if he had asked me if he could search my car. I would tell him: Officer, I understand you trying to keep us safe and I'm law abiding citizen with nothing to hide but I do not consent to searches.
    I stay away from Nazi states that border with PA but sometimes I have to cross into them. Let see, NJ leo pulls me over: sir could i search you car. Sure, sir. I have nothing to hide.
    Is this a 9mm brass AND one "LIFE" round under your seat!!!
    Is this a shotgun shell?
    Well sir, I go to range once a week and I reload.
    You don't have "purchase card" Please put your hand behind your back... FELONY
    Is this a knife?
    I use that for emergencies and fishing.
    The blade is longer then ...
    Is this a pepper spray?
    Is this a radar detector?
    Here is your ticket for that
    Is this a hand gun barrel?
    Oh, that thing, that is from my 22. plinker. I forgot I had that
    Is this a HANDGUN?!!!
    Sir, when I made that left I ended up on one way bridge. I did a legal u turn as soon as I came off a bridge and I was heading back to my state....
    FELONY 2 years minimum
    Do you have prescription for this?
    Yes sir, but for convenience I put some pills in my pill carrier.
    I could go on and on. Things that could get me in trouble that I might have by chance or did not know it's there or forgot I have.
    I'M NOT LOOKING FOR ARGUMENT. Since we started talking about searches I just wanted to show how quickly it could go wrong at least for me. And by refusing a search you protect a constitution at same time.
    What i want is to find out how to make a key that opens door but doesn't start the truck :))
    If you have a "hidden compartment" you can be charged with a felony crime. The guy arrested in this story didn't actually have any illegal drugs:
    http://www.tacomaworld.com/forum/gen...nt-felony.html
    Watch this, guy going to jail for shotgun shell. This happens everyday, law abiding citizens go to jail because of draconian law made by libtards.
    http://video.foxnews.com/v/31872347...-ammo/?playlist_id=938973798001#sp=show-clips
