Key Trouble
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TerryTac0, Jun 9, 2022.
  1. Jun 9, 2022 at 7:49 AM
    TerryTac0
    TerryTac0 [OP] Well-Known Member
    2006 DCSB 225k
    I have noticed over the past month some trouble starting the truck. When inserting the key into the ignition it becomes difficult to turn.
    This different than when the steering wheel is locked out.
    I have noticed that the primary key I use is more worn than the valet key.
    The other key is somehow wired into the remote start system. I need to look and see if that can be swapped with the worn out key.
    Any issues to using the valet key all the time?
  2. Jun 9, 2022 at 11:21 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Nope the only difference between the Valet and regular key is the color.
    TerryTac0[QUOTED][OP] likes this.
  3. Jun 9, 2022 at 11:22 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    As @Jimmyh said, you can use the “Valet Key” all the time.
    The only thing you can’t do with the “Valet Key” is make a copy of it.
    Technically, you can physical copy that unlocks the doors, but it won’t start the truck.
    Only a master key (Black) can be copied. As it will allow a copy of the immobilizer data to be transferred to a new key.
    My point is, be sure to take the Black key with you if you get a new key made.:thumbsup:
    Jimmyh and TerryTac0[OP] like this.
