key wont come out of the ignition
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98THOR, Jan 23, 2014.
  1. Jan 23, 2014 at 3:17 PM
    98THOR
    98THOR [OP] Well-Known Member
    Hawaii
    98 ex. tacoma 4x4
    33x12.50 nitto mud grapplers, Pro Comp eXtreme alloy wheels 17x9, Fabtech/fox adjustable coilovers in the front, Fabtech rear shocks, 3" body lift, Tint, K&N air filter
    so just recently my car dosnt turn 'off' or come out of the ignition unless i disconnect my battery :( anyone know whats wrong with it??
  2. Jan 23, 2014 at 3:18 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Is it in park?
  3. Jan 23, 2014 at 3:24 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    did you push in on the key some?
    Kiloyard likes this.
  4. Jan 23, 2014 at 3:25 PM
    HawaiiTRD
    HawaiiTRD "Some people feel the rain, others just get wet"
    Hawaii
    2022 MGM DCSB TRDOR
    Diamondback SE, FITCAMX
    Might sound stupid but are you in "park"? Key won't turn to off or come out if not in park. Also, I've read that some people would shift between gears and the key would just come out.
  5. Jan 23, 2014 at 6:53 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    try turning the steering wheel. when i had ignition problems in my old 90 4runner i had to turn-lock the wheel to get it to work.
  6. Jan 23, 2014 at 8:33 PM
    Fuzzy Dustmite
    Fuzzy Dustmite Active Member
    Greg
    Mesa, AZ
    02 DLX Lunar Mist / Grey
    Along these lines, I would sometimes have to turn my steering wheel just about 1/2 an inch after it had locked to get the key out.
  7. Jan 23, 2014 at 8:45 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    My guess is that it's only going to get worse. On my 4runner it got progressively worse until we had to get a completely new ignition put it.
    Does it lock up when you try to start it?
  8. Jan 30, 2014 at 5:44 PM
    98THOR
    Hawaii
    98 ex. tacoma 4x4
    its only gotten worse i used to just crank my wheel and it would come out but not anymore and yes it is in park.
  9. Jan 30, 2014 at 5:45 PM
    98THOR
    Hawaii
    98 ex. tacoma 4x4
    i can start it just not take the key out of acc it dosnt turn to off
  10. Jan 30, 2014 at 5:46 PM
    98THOR
    Hawaii
    98 ex. tacoma 4x4
    I think it has to do with some sort of censor because when i disconnect the battery it comes right out
  11. Jan 30, 2014 at 5:47 PM
    gearcruncher
    Canadain bumper technician
    To properly adjust shifter cable , put transmission in park and "REMOVE THE Ignition KEY " Just throw it on the seat until youve made the adjustment
    Go under truck with wheels blocked ofcourse and remove the cable from from the transmission lever .
    Grab the shift lever by hand and move it to the park position .
    Go to the back of the truck and verify you cant push the truck by hand so you know the cable is in park as well as the transmission .
    Now that you know the transmission is in park and the shifter is in park , adjust the cable until it fits into the hole on the shift lever .
    Verify the truck will only start in park and nuetral .
    The Key to proper adjustment is removing the Key[​IMG]
  12. Jan 30, 2014 at 8:04 PM
    Card1
    Card1 Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    My t100 use to do that, i had some effed up alarm system in there that i hated lol. We disconnected most of that and i think going through the gears would do it. i don't remember for sure though?
  13. Feb 25, 2017 at 11:37 AM
    Glamisman
    Glamisman Well-Known Member
    reply to a thread that is 2+ years old...
    I too could not turn the key to the "Lock" position from the On position. What I found, 1996 Tacoma 4WD Automatic, was that the bushing for the shifter were worn out an had broken into many, many pieces allowing for too much slop in the pivot points, two places, for the shifter. 4 bushings from the dealer, $14. It will take maybe 2 hrs to do the job and the only warning that I can give is to remove the metal center bushings(6) from the rubber isolation/seal after you remove the 6 bolts that hold the shifter plate to the trans tunnel. They have to be removed to allow you to push the rubber shield down so that you can access the lower shifter pivot nut assembly.
  14. May 5, 2020 at 11:11 AM
    epharp
    epharp New Member
    Patrick
    1998 Tacoma 2.4L
    I try to remove the ignition switch from my 1998 Tacoma xcab 2.4L, I disconnect the battery, I turn the key to ACC, I fully depress the release pin but the switch only comes out about 1/4 inch and that's it. Is there some additional step or trick to get the switch out?
    Thanks,
    Patrick
  15. May 5, 2020 at 4:12 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Shifter bushings are toast. Replace them.
  16. May 5, 2020 at 6:51 PM
    Glamisman
    an explanation to KdF's reply. There is a shifter interlock located in the center console. When the shifter is pushed into park a switch is closed and this allows the lever that locks the key in the ignition cylinder to release. pushing forward on the shifter while in park overcomes the slop in the bearings and allows the switch to close. If this isnt the case then the cylinder is wore.
  17. Jan 1, 2025 at 2:12 PM
    Pv1940
    Pv1940 New Member
    Edward
    As for the problem with getting the ignition assy out. I also had issues. Pressing the Little button is not all. They do not tell you about the Little blacklight ring that also has to come out. Another little screw has to be taken out and then the backlight ring will come out. Then push the button and the key ignition assy comes out.
