Key won't turn, only choice is very expensive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dave91, Jul 26, 2015.
  1. Jul 27, 2015 at 5:45 PM
    OCNutty
    OCNutty Well-Known Member
    Northern, Va.
    Silver Prerunner DC v6 SR5 Tow
    Agree with others; this is a mechanical problem and a locksmith should be contacted. The 'barrel'
    should be resettable (re-keyed) with pins to match your existing keys. This is assuming the barrel is at fault instead of the key just being worn out.
    So, agree to try your backup key. The key ur using may be too worn to work.
    If you need a new key, you'll need a master key for the system to recognize if you want Toyota to sell you a blank and cut/program it into the truck computer. If your 'spare' key is a valet key, the chip system in the truck won't be able to accept an additional key programmed into the system.
    Another way to get a new key is to get the old one 'cloned' which can be done at Ace Hardware as I understand. In this the tech copies and burns in the information from the transponder into a replacement key transponder which then will be recognized. If your old key can be used to cut the metal shaft properly you're back in business.
  2. Jul 28, 2015 at 10:28 AM
    dave91
    dave91 [OP] Well-Known Member
    dave
    quebec
    Well good news, i tried my other key and it worked perfectly!
    Ill upload a picture later of the two keys... its crazy how worn the other key was!
    They told me i should probably get a new key made, better to have two, and incase the problem happens again.
    Apparently i can just go to the dealer and give them the serial number and theyll make me a new key for around 40-50$
    Mademan925 likes this.
  3. Jul 28, 2015 at 10:37 AM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    my base has a chipped key. same convenience package also.. hmm
  4. Jul 28, 2015 at 10:47 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Tacomaworld comes through again. Dudes on here are impressive. Glad it worked out.
    R0dzilla75 likes this.
  5. Jul 28, 2015 at 2:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you expect anything less...?
  6. Jul 28, 2015 at 3:02 PM
    Clearwater Bill
    Billy
    Largo Florida
    Your profile says pre runner.
    I have a base.
    Is your profile incorrect?
  7. Jul 28, 2015 at 3:12 PM
    ramonortiz55
    Ramon
    Texas
    stock
    yes i have a prerunner.
    im thinking base prerunner.. no dealer added options per se.
  8. Jul 28, 2015 at 3:17 PM
    Clearwater Bill
    Billy
    Largo Florida
    a pre runner is a very different vehicle than a base in many ways.
    Lets start with wheels. I have 5 lugs. You have 6. I have black bumpers front and rear, and a all black grill. I sit much lower to the ground than you, as you have a different suspension. Along with many other differences. And you have a chipped key, I don't :thumbsup:
  9. Jul 28, 2015 at 3:33 PM
    ramonortiz55
    Ramon
    Texas
    stock
    yes i know. haha.. i was thinking base prerunner. but I know what you mean now.
    youre the one with the little donut tires.
  10. Jul 28, 2015 at 3:46 PM
    Clearwater Bill
    Billy
    Largo Florida
    All in the eye of the beholder. I see low TCO while doing everything I want it to do. Perfect for what I need. Hauls kayaks and bicycles quite well, is cheap to maintain, and gets a consistent 20mpg in town (AC on) and pushes 30 on the road. Couldn't be happier.
    Well, I'd be happier with no TPMS. One day it will be properly disabled. :cool:
    ramonortiz55[QUOTED] likes this.
  11. Jul 28, 2015 at 9:35 PM
    dave91
    dave
    quebec
    And thats why im on here... TW always answers my questions and has helped me out so much. Thank you all!!
  12. Mar 26, 2017 at 1:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is for unlocking the shift lever and take it out of park without a key.
    theredofshaw likes this.
  13. Apr 20, 2017 at 11:59 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I get a kick out of those base models, they look so small sitting on those little tires. Ha
  14. Apr 20, 2017 at 12:16 PM
    ramonortiz55
    Ramon
    Texas
    stock
    two years ago bruh..
    stickyTaco likes this.
  15. Apr 20, 2017 at 12:26 PM
    #35
    taco2010trd
    Tampa, Florida
    Oops my bad
  16. Apr 20, 2017 at 12:39 PM
    #36
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  17. Apr 20, 2017 at 12:43 PM
    #37
    TacomaMike37
    13' DCLB MGM
    Jimmyh and T4RFTMFW like this.
  18. Apr 20, 2017 at 12:54 PM
    #38
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    4cyl never has chipped key regardless of trim package.
    V6 always has chipped key regardless of trim package.
    So it is entirely down to which engine you have.
  19. Apr 20, 2017 at 12:55 PM
    #39
    ramonortiz55
    Ramon
    Texas
    stock
    stupid engines gotta ruin everything
  20. Apr 21, 2017 at 4:51 AM
    #40
    Jimmyh
    SC
    2012 Prerunner SR5
    Obviously
    No. It won't.
