Key won't turn
Discussion in '1st Gen. Tacomas (1995-2004)' started by ffirg, Sep 26, 2011.
  1. Sep 26, 2011 at 10:26 PM
    ffirg
    ffirg [OP] Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I'm posting this for my brother, who has a 2001 xtra cab. 3.4L manual transmission. When he tried to leave for work this morning his key would not turn in the ignition. It will occasionally get far enough for the stereo and heater blower to run, but not far enough to have the starter engage. It's parked in a level driveway with the wheels straight. No, the wheel is not locked, we already looked into that. I tried using lock de-icer because it was below freezing this morning. 4wd is not engaged, we tried rolling it down the driveway to see if we could loosen any pressure on the steering column, but no luck there either. Any ideas on how to fix this?
  2. Sep 26, 2011 at 10:46 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Ignition lock cylinder is toast. Tumblers are most likely broken inside. Before he does anymore damage, stop trying to start it. Find a used lock cylinder and key and replace it. The idea is to be able to turn it ACC and push a little button and the lock cylinder slides out. If you cant turn to ACC, its a bitch of a job to get it out.
  3. Sep 26, 2011 at 10:52 PM
    ffirg
    mike
    Anchorage, Alaska
    Excuse me if this is a dumb question, but if he does that and gets a new key, won't he need to get the locks changed in his doors then? And thanks for the quick reply by the way. I'll tell him to stop forcing it.
  4. Sep 26, 2011 at 10:57 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Same thing happened to me and at a gas station with a full tank of gas. I kept forcing it for 2 hours until i couldnt get the key even in. Had to leave the truck over night and get it towed to my shop. Bought a lock cylinder w/ key for $60 at auto wreckers and replaced it. What a pain!!!!
    And yes i have two keys.
  5. Sep 26, 2011 at 11:01 PM
    ffirg
    mike
    Anchorage, Alaska
    Alright, thanks guys. I'll spread the good/bad news. I hope he is happy with 2 keys and I am just glad this did not happen to me. do you have to take the whole dash apart or just the two panels around the ignition/clock?
  6. Sep 26, 2011 at 11:07 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Basically you want to expose the underside of the cylinder so you can push a button and release the lock.
  7. Sep 26, 2011 at 11:08 PM
    Will Prerunner
    Will Prerunner Well-Known Member
    Tempe Az
    01 TRD Prerunner Doublecab
    Trail-Gear rock sliders, OME Lift, kobalt tool box, herculined fender flares, CrossFab light bar, Deck plate Mod, Differential Breather Extension, 32"goodyear duratracs Pioneer 3 way speakers, alpine head unit, Boss Bass 600 sub, custom az pinstriping
    Similar thing has happened to me twice, both times I just kept messing with it, turning the wheel back and forth, and within about 30 minutes was able to get it to turn, had the best luck trying to turn it with the key pulled out slighty more than normal. The wierd thing was both times the wheel wouldn't lock up like it normally does when turned.
  8. Sep 26, 2011 at 11:14 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i just jiggle mine..
  9. Sep 26, 2011 at 11:18 PM
    J0hnMata
    J0hnMata Well-Known Member
    Orange County
    09 PreRunner
    BHLM, bilstein 5100's, satoshi grillcraft grill, k&n cold air intake, tinted windows all around, interior map and dome light led's, hid fog lights and headlights, yellow fog light lenses, black lower valence.
    thats what she said
  10. Sep 27, 2011 at 12:45 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    have you check to see if key is bad? never happen to me but if it does screw driver is my best friend:D
  11. Sep 27, 2011 at 1:04 AM
    SpazzyB
    SpazzyB Master of the Prius...
    Ryen
    neuf un six
    '04.5 vw stance machine
    who is this "she"? sounds like a whore. :D
  12. Sep 27, 2011 at 9:28 AM
    SargeSlapnuts
    SargeSlapnuts SargeSlapnuts 보고용의!!!!
    Nick
    alpharetta, GA
    2004 TRD 4x4 converted PreRunner SR5 lifted l
    255/85-16 tires, front push bar w/9000lb winch, driver and passenger windows tinted to match factory rear tint, quick at home spray on bedliner, hid's, lifted with 3"toytec rear lift kit and ome front lift, locked with powertrax, and a cb radio in place of ash tray, fog light mod, diff breather mod, greasable shackles, Home made Baja Rack, "extra" bright reverse lights. also converted to 4x4 safari snorkel
    there is a park safety key turn preventoin thingy on the key cylinder. unbolt it and the key might turn. i had the same problem myself a while back
  13. Sep 28, 2011 at 1:40 PM
    ffirg
    mike
    Anchorage, Alaska
    Alright thanks guys. I ended up towing him to a locksmith. They said the tumblers need to be fixed and they'll do it for 20 bucks. We'll try that first and see if it fixes the problem.
