Key won't turn
Discussion in '1st Gen. Tacomas (1995-2004)' started by Supra TT, Feb 4, 2013.
  1. Feb 4, 2013 at 5:35 PM
    Supra TT
    Supra TT [OP] Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    As the title says, however the battery is dead and won't hold charges. Does the ignition need to see voltages before it can turn? I always thought it was mechanical in a way... It won't move at all, not to run, or acc, or start. ZILCH
    Before dumb questions arise, yes the steering wheel freely moves back and forth as I turn the key, and it's in park...
    Never had this issue ever, however never had a completely dead battery in the frozen tundra we are all experiencing.
    Thanks :cool:
  2. Feb 4, 2013 at 5:47 PM
    Madjik_Man
    Colorado Front Range
    My key wouldn't turn but my steering wheel would freely move (as much as I could with the truck off).
    My battery was fine though.
    Turned out to be a worn out ignition lock cylinder.
    Had to get a whole new tumbler, etc and get it re-keyed. (didn't want two keys, one for the ignition, one for the door locks)
  3. Feb 4, 2013 at 5:50 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Spring for a new key.
  4. Feb 4, 2013 at 5:52 PM
    Madjik_Man
  5. Feb 4, 2013 at 5:54 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    X2 on ign lock cylinder. The tumblers get worn out after sometime.
  6. Feb 4, 2013 at 5:56 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    I've never heard of an electrical lock-out.
    I'd look at how worn the teeth on the key is. I've been warned by some long-time toyota owners to tuck away a spare because the cylinders don't like worn teeth. If the teeth look good, as Madjik_Man pointed out, I'd go to the cylinder as the next highest possible cause.
    Might also be beneficial to borrow a battery from a buddy.
    (I said that just to get the alliteration in.)
  7. Feb 4, 2013 at 6:06 PM
    DueToThe802
    DueToThe802 Well-Known Member
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    I'm a locksmith, and see this quite a bit. I'd guess the key is worn more than the wafers. What year is the taco?
  8. Feb 4, 2013 at 6:14 PM
    Madjik_Man
    And just FWIW
    My old key worked in the door locks just fine when it wouldn't turn the ignition cylinder.
  9. Feb 4, 2013 at 6:15 PM
    Tacoma Mike
    Southern Maine
    This
    We have seen this quite a few times. A key is cheap first step.
    You need to have it cut by code at the dealer though, not by tracing.
  10. Feb 4, 2013 at 7:01 PM
    tylershane17
    tylershane17 Back to Back World War Champions
    Tyler
    Northwest Alabama
    2007 TRD OFF ROAD DCSB
    Brushguard, Lift.
    x2
  11. Feb 4, 2013 at 7:04 PM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    You'd also be amazed at what some wd-40 can do. Or tri flow.
  12. Feb 4, 2013 at 7:06 PM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    Yea I've never tried tri flow. Either WD40 or PB Blaster are 2 of the greatest things known to man.
  13. Feb 4, 2013 at 7:11 PM
    Supra TT
    Eric
    Indiana
    Guess I will try my spare tomorrow. I was able to get it to start yesterday after hundreds of attempts, it finally went through. The truck is a 2000, original key from what I can tell. Spare key it is.... I'll report back tomorrow.
  14. Feb 4, 2013 at 7:13 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Yep. I had this problem with my '99 too. It was real fun when the alarm would start to sound 15 seconds after the door opened. :)
    Jiggling the key up & down would get it to turn (but not always).
    Most of the time it worked just fine.
  15. Feb 4, 2013 at 7:34 PM
    DueToThe802
    Sean
    Colorado
    05 TRD Off Road
    TRD exhaust
    Since it does turn, my bets on a worn key. If the spare works first try, get it copied quick. The keys will wear quicker than the cylinder, since they have springs holding them in place and they end up rubbing the key each time you use it. 13 years is a good life on the original.
  16. Feb 5, 2013 at 7:27 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Replace and rekey a new ign switch. A new key will only buy you a little time. Remove the panel over the switch, push button on the side of the tumbler, turn key, pull switch out. Reverse for install. The IGN can be operated without the switch installed, if you wanted to drive it to the locksmith/dealer.
  17. Feb 5, 2013 at 9:42 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Except he wont be able to push the button to release the the ign lock cylinder. In order to release the cylinder, you have to be able to turn key to ACC position. You will have to smash the button with a punch until it breaks through and releases.
    Just like i had to do... in a parking lot... 30 mins from home... with dirty mike and the boys wanting to have an orgy in my truck
  18. Feb 5, 2013 at 10:46 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    folk may prematurely damage the tumblers in their ign. cylinder
    by having too many keys dangling from their key fob.
    I recommend using a single key in the ign.
    or use a take apart key fob that removes the added weight
    and leverage of extra keys dangling.
    I use a single key and have done so for 13 years on muh junk.
    likewise with most of my prior/current vehicles.
    my learning comes from my personal experience
    when I was young and driving/owning my first car.
    Back then I didn't know much.
    a fubar'd ign. lock cylinder changed my assessment of the matter
    and I removed the unnecessary weight from the key fob,
    and have never had ign. cyl. issues since.
  19. Feb 5, 2013 at 4:22 PM
    Supra TT
    Eric
    Indiana
    Worn out key... Tried my spare and worked every single time like it was new again. Thanks guys :cool:
  20. Feb 5, 2013 at 4:24 PM
    Tacoma Mike
    Southern Maine
    Sometimes the simple things .... Good for you...:thumbsup:
