Keyless entry/ Ant theft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ghost_dogo2, Jan 30, 2024.
  1. Jan 30, 2024 at 7:19 AM
    Ghost_dogo2
    Ghost_dogo2 [OP] Member
    Hello everyone, I'm new to this community.
    I just recently bought a 2011 Toyota Tacoma TRD off-road base model. When I bought the vehicle, it didn't have keyless entry. I did some searching around but couldn't find the answer to my problem. How do I add keyless entry?
    After doing some looking around on the vehicle, I noticed it was wired for an anti-theft system, but it didn't seem to function. I also noticed a cable in my glove box and thought, maybe by installing the door control module it would allow me to have keyless entry. Does the keyless entry only work if I have a functioning anti-theft system? What, parts do I need to make the Anti-theft system work? and will it allow me to have keyless entry?
    Any help would be greatly appreciated.
    Update: I don't think the vehicle has the ignition key amplifier. Is this something I can add that will solve my issue?
  2. Jan 30, 2024 at 7:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The antitheft (Immobilizer) and remote keyless entry are 2 separate and unrelated systems.
    To add remote keyless entry the truck must already have power locks and the connector for the Door Control Reciever behind the glove box, if it does then it's just a matter of getting a Door Control Reciever and the key fobs that match it then installing it and going through the steps to program the fobs.
    There's several threads about it if you poke around.
    https://www.tacomaworld.com/threads/how-do-you-determine-if-tacoma-came-with-keyless-entry.491446/
    GilbertOz, tcjacado and 1schoir like this.
  3. Jan 30, 2024 at 7:34 AM
    Ghost_dogo2
    Dm93,
    I saw this thread; I bought a receiver off eBay for about 120$. I installed the door control module and tried to program it again. To program the fob, all the videos discussed having to insert the key into the ignition, open and close the doors, etc. Due to the absence of a chime when inserting the key, I thought the two had to be connected. Is there some other way of programming the key fob that only a locksmith or Toyota dealer can do?
  4. Jan 30, 2024 at 8:47 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That's an issue with the key in (Unlock Warning) switch in the lock cylinder, you have to have that working before your gona be able to program fobs.
  5. Jan 30, 2024 at 10:16 AM
    Ghost_dogo2
    Understood, I will get that checked out. Thank you for your help.
  6. Jan 30, 2024 at 10:52 AM
    Ghost_dogo2
    Update: I saw your other thread on the Unlock warning switch problem.
    https://www.tacomaworld.com/threads/remotes-stopped-working-chime-key-ignition.751304/
    I did those steps, and it seems the unlock switch works. With the key out and the door ajar, the door locks and stays locked. With the key in the acc position the door locks and then unlocks. I believe you said in that thread, that the key-in beeper is in the combination meter. Does the key-in beeper control the programming even though it's a separate part from the unlock switch?
    Also, if the key-in beeper controls the programming, do I need to replace my instrument cluster?
  7. Jan 30, 2024 at 10:59 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What about if the key is inserted but the ignition is off?
  8. Jan 30, 2024 at 11:00 AM
    Ghost_dogo2
    With the key just inserted and the ignition off (in the lock position), the door locks and stays locked.
  9. Jan 30, 2024 at 11:04 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Then the switch isn't working properly, it's probably the switch itself but your gona have to get into the column and see.
  10. Jan 30, 2024 at 11:11 AM
    Ghost_dogo2
    Thank you,
    I will take a look tonight and see if it's a problem with the switch.
    Dm93 likes this.
  11. Jan 30, 2024 at 6:27 PM
    Ghost_dogo2
    Update:
    I just took apart the steering column and looked at the switch. There was no noticeable damage. I did notice the lock cylinder itself seems to be loose. However, I also noticed, that when I got in the car and pressed on the lock with the key in the lock position, while also pressing the key towards the engine, the doors locked and unlocked. I.e. the same issue TnShooter had in the aforementioned thread.
  12. Jan 30, 2024 at 8:03 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I have yet to have to deal with mine, it still works like it's supposed to but it seems to be a fairly common issue.
    I'm not sure if it's due to wear in the lock cylinder or the switch itself.
  13. Jan 30, 2024 at 8:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Using a newer key resolved my issue.
    My key was so worn it was loose in the ignition.
    Ghost_dogo2[QUOTED][OP] and Dm93 like this.
